ICE Air Filter Question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AzWxGuy, Apr 14, 2012.
  1. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    559
    Tucson, AZ
    2021 Prius
    Today was a big maintenance day, change oil/filter, air filter, serpentine belt, and rotate tires. I just recently rolled over 100K miles and it was time for some diligent maintenance. I noticed on the removable top cover of the ICE air filter that there is what appears to be a post-filter or engine backfire retarder of some sort. On close inspection it looks more like a final stage very fine filter. It also looks quite dirty. Anyone know anything about this? Does it have to be replaced periodically as an integral part of the air filter top cover? Can it be cleaned?
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  3. Patrick Wong
    18,210
    6,526
    That contains charcoal. The idea is to absorb HC that comes up from the intake manifold, as a smog-prevention measure. No maintenance is required, leave it alone.
    2 people like this.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Have you changed the trans fluid yet? if not your way overdue.
  5. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    559
    Tucson, AZ
    2021 Prius
    Oh yes. Changed by the dealer at 91K as recommended. I felt confident that I could have done it myself, but then what to do to properly recycle quarts of hazardous waste. In the end I decided it was worth having the dealer do it.
    In regard to my air filter box, I will leave well enough alone.
  6. Patrick Wong
    18,210
    6,526
    One easy and simple way to get rid of used automotive fluids is just to take them to your local Pima County landfill which will have a recycling area for those items. I use the Sahuarita landfill since I am located south of Tucson.
    PDEQ Landfills and Transfer Stations - Locations and Hours of Operation
