ICE comes on anyway
Discussion in 'Prime Main Forum (2017-2022)' started by priuscatprimeguy, Feb 26, 2017.
  1. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    What this has to do with regeneration of a full battery?
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    nothing, nothing at all, but ICE kicks in because it's cold out, and it's not any of your mumbo jumbo
    52,863
    i think we've argued the same points several times over. :cool:
    as i recall, with the pip, there were a few people whose engines would come on for 'no reason', and we could never figure it out.
    i have one route that always starts the engine in cold weather at a half mile out. any other direction i go, and it never comes on.
    HPrimeAdvanced likes this.
  4. priuscatprimeguy
    2,730
    2,640
    and your car sits in an unheated garage?
  5. bisco
    52,863
    yes. but with the pip, as with prime, some folks were outside, and some were in. the cold is definitely part of your problem, but we haven't figured out the battery conditioner yet, either.
    also, i think if cold were the only factor, it would fire up like a lift back. after all, when you start driving, it's only getting warmer, and a million other factors come into play.
    prime is supposed to limit engine firing much more than pip, but not completely like a volt.
    priuscatprimeguy likes this.
  6. dalcon95
    dalcon95 Senior Member
    512
    653
    Easley, South Carolina
    I think comparing the PIP to the Prime is like comparing tangerines to oranges. They not exactly the same. The Prime is designed to stay in EV only for more situations and circumstances.
    #1 in Easley,SC
    HPrimeAdvanced and bisco like this.
  7. priuscatprimeguy
    2,730
    2,640
    Like I said, Toyota likes to see us bicker:p
    HPrimeAdvanced, dalcon95 and bisco like this.
  8. bisco
    52,863
    no question, pip is much different. but the knowledge base helps give us clues. still, the prime is so complicated, and has so many features and screens, idk if we'll ever figure it out.
    we'd need a cold weather bob wilson, and there is no other.
    priuscatprimeguy and dalcon95 like this.
  9. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    It is not Toyota - it is you
  10. priuscatprimeguy
    2,730
    2,640
    too bad there's no way I can unfriend you, I know! I can ignore you!:p
  11. dalcon95
    512
    653
    I think Toyota may enjoy us talking about unengineering (starting with the end result and working backwards to get to the engineering of the result) their products when they pretty much know all about it without telling us. Decades ago, they did that with American products.
    #1 in Easley,SC
  12. El Dobro
    El Dobro A Member
    7,106
    3,282
    To borrow a quote, " what difference at this point does it make?". Whether you like it or not, the ICE is going to start and you're not going to stop it. ;)
  13. priuscatprimeguy
    2,730
    2,640
    not true, I can drive down the side streets at 25 MPH for about 1.5-2.0 miles and ICE will not come on until I reach the 124 mile interval.:D
    #213 priuscatprimeguy, Mar 13, 2017
  14. bisco
    52,863
    you're already at post #217, it won't come on again until 248.:whistle:
  15. priuscatprimeguy
    2,730
    2,640
    I have no Idea what you mean @bisco?:p
  16. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Because a report above says it hasn't started in 800 miles, leading to the possible conclusion that the report of this behavior (starting every 200 miles) isn't true.
    dalcon95 likes this.
  17. priuscatprimeguy
    2,730
    2,640
    could you please provide that link to that quote? Am I to assume that ICE was off for that total 800 miles?
  18. dalcon95
    512
    653
    [quote uid=5889 name="bisco" post=2509816]is this conclusion out the door now?[/QUOTE]I know this isn't the case being I personal have driven over 800 miles and not use a drop of gas.
    #1 in Easley,SC
    #1 in Easley,SC
  19. priuscatprimeguy
    2,730
    2,640
    #1 in Easley,SC
    #1 in Easley,SC[/QUOTE]
    That's bisco and he drives a 2012 PIP which means ICE has, in fact, kicked in after 124 miles:D
  20. dalcon95
    512
    653
    I haven't gone beyond 800 miles because I purposely went on a long distance trip to verify another thread about getting more EV range going down a mountain. Started over after that and have driven 400 miles so far this time without using a drop of gas and going......
    #1 in Easley,SC
