ICE comes on anyway
Discussion in 'Prime Main Forum (2017-2022)' started by priuscatprimeguy, Feb 26, 2017.
  1. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    wow, ok, well then I should be able to go 400 miles in all EV driving down side streets at 25 MPH for the first 1.5- 2.0 miles, I'll get back to you on that
    dalcon95 likes this.
  2. dalcon95
    dalcon95 Senior Member
    512
    653
    Easley, South Carolina
    Keep in mind, I am using a Prime, not a PIP. And I keep all the parameters that I have mentioned earlier in this thread.
    #1 in Easley,SC
  3. El Dobro
    El Dobro A Member
    7,106
    3,282
    It's possible, with the greater EV range of the Prime over the PiP that Toyota switched over to time, as opposed to mileage, for an EMM. The Volt uses 6 weeks as a target for EMM.
  4. priuscatprimeguy
    2,730
    2,640
    duly noted #1 in Easley, SC:D
  5. priuscatprimeguy
    2,730
    2,640
    according to your ECO ranking you have 362.55 miles. and you're in 4th place. the highest EV is 671.15 miles. mine took a nose dive after yesterday's fiasco, 260.7 miles EV and I'm 140th:cry:
  6. dalcon95
    512
    653
    Sorry to hear that. I have more miles added to that from last month after I stopped using gas and topped off the gas tank.
    #1 in Easley,SC
    priuscatprimeguy likes this.
  7. priuscatprimeguy
    2,730
    2,640
    I don't see you listed for the month of February, mine was 201.58 January for you was 794.39
  8. bisco
    52,863
    maybe climate change will solve this problem for everyone.
  9. Tom_06
    Tom_06 Active Member
    609
    142
    Newark, Delaware, USA
    Both me and my car must have missed that in the manual. I have exceeded 200 miles without an engine start at least twice.
  10. dalcon95
    512
    653
    I drove on a 320 mile trip through the mountains and knocked me out of the ball park.
    #1 in Easley,SC
  11. CharlesH
    2,798
    1,166
    Roseville, CA
    The "ICE starts due to regeneration to full battery" point has been mentioned, but have any conclusions been reached about this? With the PiP, there were folks who lived at the top of a hill, and after their PiP was fully changed, and they started down the hill, the ICE would start to warm the engine so the system could use engine braking to dissipate the energy. Presumably, something similar could happen if there was a hard stop very soon after starting a trip, or would the system just use the friction brakes in this case?
    I live in the California Central Valley, so the 14 °F threshold for starting the engine for heat does not apply in my case. :)
  12. bisco
    52,863
    the only conclusion in this thread is that we have a lot to learn.:cool:
  13. CharlesH
    2,798
    1,166
    Roseville, CA
    Replying to my own post, this issue is discussed here: Full Battery & going downhill - Engine coming on? | PriusChat The conclusion being that the Prime behaves just like the PiP in this regard, although there is a conjecture that there is a short warmup cycle that is used in this case.
  14. bisco
    52,863
    sounds right, but can we conclude that hard braking is the equivalent? or that o/p even does any?
  15. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    That depends on who you ask.
    The O/P concluded that the whole thing of preventing regeneration to a full battery is not more than mambo-jambo.
    If you ask me, after 200+ posts this may be the only explanation to what he is experiencing (over 3 cars now and always in the same place and conditions). The fact that ICE is not starting on him in cold morning when battery is not full strengthen this possibility.
    According to his report - he does, 2-3 blocks after starting.
  16. bisco
    52,863
    maybe throw it in neutral, and see what shakes out.
  17. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Yes, but this would kill the thread too early:)
    dalcon95 and bisco like this.
  18. priuscatprimeguy
    2,730
    2,640
    well, at least Remote Climate is working, thawed out my windshield front and back. And a nice toasty cabin:D
    Nic Steussy, bisco and dalcon95 like this.
  19. bwilson4web
    16,537
  20. thatoneraccoon
    thatoneraccoon Active Member
    201
    146
    Ohio
    Just to note: my garage is unheated but usually still a few degrees warmer than outside. Like this morning was 22 via temp sensor on front porch. 26 via my prime when I turned it on.
