ICE comes on anyway
Discussion in 'Prime Main Forum (2017-2022)' started by priuscatprimeguy, Feb 26, 2017.
  1. bisco
    52,849
    so once the battery is warm, the ice stops coming on?
    52,849
    how many users are getting an outdoor cold soak every night?
    thatoneraccoon likes this.
  3. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    correct:D
    52,849
    that's exactly how the pip works. maybe you'll have to leave it overnight.
  5. priuscatprimeguy
    2,730
    2,640
    and with the warm weather we have been having I better make it quick:eek:
  6. bisco
    52,849
    agreed, you don't want to wait until next winter, when the warranty may not cover it.
  7. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Just a longshot - are you driving in "B" position and not "D"?
  8. thatoneraccoon
    thatoneraccoon Active Member
    201
    146
    Ohio
    I've tried driving around in "B" in town and on freeway and it's not caused my prime to fire up the ol ICE
  9. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    I think it can, in the first few miles after full charge, when you let-off the pedal.
  10. thatoneraccoon
    201
    146
    Ohio
    I just remembered something, I think I saw something about a battery heater in the menu somewhere when I was playing around with it. I remember turning it on. Also I believe I saw something for AC for the battery also. Perhaps get lucky and it's something that easy, if you haven't already done so. If you have, it sure sounds like the battery heater not working... Leaving plugged in over night too?
  11. thatoneraccoon
    201
    146
    Ohio
    Hmmm ya know, that may make since. I think I've read that if battery is full and using B can cause the ice to fire and use engine brake because batt is full.
  12. huskers
    huskers Senior Member
    2,549
    2,488
    Nebraska
    You would think that would be a default setting.
  13. thatoneraccoon
    201
    146
    Ohio
    I know right, plus I also just realized that still may not be the problem. My car sits outside all day at work, not plugged in and it still stays EV only.. hmm
  14. bisco
    52,849
    not plugged in maybe better. a full battery doesn't like any regen when it's cold.
  15. zxcvbn
    zxcvbn Junior Member
    space
    Anybody else having this same problem in cold weather?
  16. priuscatprimeguy
    2,730
    2,640
    nope, I'm sure it's "D"
  17. priuscatprimeguy
    2,730
    2,640
    checked Battery Traction heater, it's on never switched it off
  18. priuscatprimeguy
    2,730
    2,640
    Actually I'm making a left turn onto 14 mile road then when I complete the left turn I accelerate to 35 MPH. Once I get to 35 MPH ICE kicks in so no regen.
  19. bisco
    52,849
    it's not the cold, it's the 'charging outside overnight'.
  20. priuscatprimeguy
    2,730
    2,640
    it's also the cold
