ICE comes on anyway
Discussion in 'Prime Main Forum (2017-2022)' started by priuscatprimeguy, Feb 26, 2017.
  1. bisco
    52,863
    must be overnight.
    priuscatprimeguy likes this.
  2. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    That blows chunks!!! I think there are corporate troubleshooter specialists that need to be summoned; the problem is to convince the ##$$%@^ dealer to take you seriously!! Make sure you talk to Corporate, and get names. Don't forget, the squeaky wheel gets the grease! If you need to collect letters of support for your cause, please let me know so I'll send one! Last resort, ATTORNEY!!
    priuscatprimeguy and pilotgrrl like this.
  3. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    @HPrimeAdvanced said "Make sure you talk to Corporate, and get names. Don't forget, the squeaky wheel gets the grease! If you need to collect letters of support for your cause, please let me know so I'll send one! Last resort, ATTORNEY!!"
    I suggest recording your calls to corporate, especially if you get the standard "this call may be monitored or recorded for quality or training purposes" line.
  4. huskers
    huskers Senior Member
    2,550
    2,489
    Nebraska
    My ICE came on today for the 1st time in a long time. I was running the defrost so I am wondering if that caused it to come on or if it was the periodic come on. Only stayed on for less than a minute. Was 37 degrees outside.
  5. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    probably the fact you turned on the front defrost.
    Nic Steussy and HPrimeAdvanced like this.
  6. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Note the second to the last bullet.
  7. priuscatprimeguy
    2,730
    2,640
    Yeah yeah, that's probably what my Toyota dealer is going to say "when the system determines that the gasoline engine needs to be started." and "the gasoline engine may also operate in circumstances other than those listed above, depending on conditions" Total BS.:mad:
    HPrimeAdvanced likes this.
  8. bisco
    52,863
    you need a dealer with another prime on the lot to test against each other.
  9. priuscatprimeguy
    2,730
    2,640
    they have a rental Prime, trick is when will it be available?
    HPrimeAdvanced and pilotgrrl like this.
  10. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    This is the phrase that they'll use to get themselves off the hook, "when the system determines that the gasoline engine needs to be started"! This seems to be a BS catch-all phrase to cover situations like yours.
    Duh, the engine will do what the hell it wants, whenever it wants!!??
    This is no answer; we're dealing with a machine, with computers, not a cat!!
    I wonder how many drunken lawyers they got to come up with that phrase!!!
    pilotgrrl and priuscatprimeguy like this.
  11. priuscatprimeguy
    2,730
    2,640
    I'm renting a Red Toyota Prius Prime Advanced starting Thursday November 9, 2017 and returning it on Monday November 13, 2017:D
    temperature on Friday is 41/35 F
    KRB17, bisco and HPrimeAdvanced like this.
  12. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    You are to be crowned, "Prius Prime Premier Technology Troubleshooter", PPPTT. I worship at your altar, oh patient one!!
  13. Trollbait
    12,831
    Could you, or them, check the air intakes and outlets for the battery. If even partially blocked, the battery temperature might get to an unhappy place, and thus the ICE starts up.
  14. KRB17
    KRB17 Member
    32
    35
    Bloomfield Hills, Michigan
    Good idea, Priuscatprimeguy. I rented a Prime from Suburban before buying so I could see if I would be happy with one. You should be able to duplicate the conditions causing your issue.
  15. priuscatprimeguy
    2,730
    2,640
    if the air intakes were blocked you would think a high temperature would trigger ICE. As you are probably aware from reading this post that ICE kicks in when the 50 F or lower threshold is reached.:confused:
    HPrimeAdvanced, pilotgrrl and bisco like this.
  16. Ducky
    Ducky Member
    33
    South Shore, MA
    If you do this (which I agree is often a good idea when you think it's possible the issue could escalate to the courts) I'd strongly suggest that you ask them if you can record first, to ensure that you don't break the law. The person you're talking to might be located in a two-party consent state where their permission is required in order to record the conversation. Better safe than sorry!
  17. "When the outside temperature is below about 14F"
    That makes sense. Because I've never had the engine come on just because of cold temps except when activating windshield defroster. This morning, I used the Remote Climate in Entune to preheat my car, max heat, because it was 24F. Once that was done, all of my commute, this morning, the engine never turned on, and the temps stayed 24F-25F even with some frost by the top of the windshield.
  18. priuscatprimeguy
    2,730
    2,640
    Yup, it's a mystery why or why not ICE kicks in. Just because ICE didn't kick in THIS time with the parameters you have chosen doesn't mean that's the case every time. For example ICE was kicking in for me when the temperature was below 50 F on several occasions then for no other apparent reason, same scenario ICE did NOT kick in on several occasions.:confused:
  19. Trollbait
    12,831
    Keep in mind that the temperature being cited is the air temperature. ICE activation is looking at the battery temperature, which is a factor of air temperature during the previous hours while it sat, and what temperature it was at when it started soaking in the cold.
    Having charging end as close as possible to your departure time means the battery is warm from the charging process.
    edit: To add, time since charging stopped is another factor to consider for this.
    #439 Trollbait, Nov 9, 2017
  20. priuscatprimeguy
    2,730
    2,640
    yup, you would think so, but ICE kicked in even when just finished charging, like I said, it's a mystery
