ICE comes on anyway
Discussion in 'Prime Main Forum (2017-2022)' started by priuscatprimeguy, Feb 26, 2017.
  1. bwilson4web
    16,552
    I tried again this morning, 41F (5C), no luck. So I switched to "Front Defrost" and found:
    • ON-engine runs-OFF - the green light comes on with ON and out with OFF.
    • If the heater is off, cycling ON-OFF, sets the AUTO mode with green light.
    • If heater is running, cycling ON-OFF, no change.
    • Duration 2:45
    Still working on iPhone video technique. But now I'm wondering if going from EV-to-HV-to-EV has the same duration?
    #681 bwilson4web, Nov 25, 2017
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
  3. priuscatprimeguy
    2,730
    2,640
    haven't figured out how to use the multi camera function in Pinnacle 21 so here's what I got, the road video is still processing should be done around 20 minutes
  4. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    I still think you have a faulty sensor somewhere. Mine has never done that even once. You were at low power, in moderate temperatures, at low speed. Your fan setting was high on the A/C. Maybe that's it?
    priuscatprimeguy likes this.
  5. priuscatprimeguy
    2,730
    2,640
    I will try again with climate off:D:cool: remember I rented another prime and had the same results
  6. Lee Jay
    5,850
    4,036
    I always have my climate on, but on auto/eco/s-flow, which usually results in modest fan settings.
  7. priuscatprimeguy
    2,730
    2,640
    mine's on Auto/ECO/s flow also
  8. priuscatprimeguy
    2,730
    2,640
  9. bisco
    52,912
  10. priuscatprimeguy
    2,730
    2,640
    thanks, need more education on dual camera videos though:cool:
    HPrimeAdvanced likes this.
  11. bisco
    52,912
    ya, i kept looking for instrumentation, or maybe we were listening for engine sound.:p
  12. priuscatprimeguy
    2,730
    2,640
  13. Lee Jay
    5,850
    4,036
    Still think there's a sensor problem somewhere.
    I've driven mine on about 700 trips without that happening even one time.
  14. priuscatprimeguy
    2,730
    2,640
  15. Lee Jay
    5,850
    4,036
    Not usually, but occasionally (like all last week while I was on vacation). About a third of those trips it was parked outside for at least 8 hours, sometimes in temperatures lower than 20 degrees F.
    I've had the ICE start four times when I didn't expect it, all four in a pretty big regeneration, all four in B mode. I've never once had it start in Drive mode when I didn't expect it to (pushing front defrost button and exceeding 85mph are the times I have expected it to).
  16. priuscatprimeguy
    2,730
    2,640
  17. bisco
    52,912
    i doubt the rental car also had the same bad sensor.
  18. priuscatprimeguy
    2,730
    2,640
    Well on the positive side that thread about charge mode utilisation to burn off excess gas I'm burning off gas the old fashioned way
  19. bisco
    52,912
    think of all the stale gas concerns other prime drivers fret over.:cool:
  20. priuscatprimeguy
    2,730
    2,640
    @Lee Jay, the reason I say eight hours is not enough is because I work eight hours and when I go home from work ICE does not kick in
