ICE comes on anyway
Discussion in 'Prime Main Forum (2017-2022)' started by priuscatprimeguy, Feb 26, 2017.
  1. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    I think you lost your "at"!! Sorry couldn't resist!!
    priuscatprimeguy likes this.
  2. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Something just occurred to me. Are you leaving it outside and unplugged?
  3. El Dobro
    El Dobro A Member
    7,106
    3,282
    HPrimeAdvanced likes this.
  4. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    lol, now it's in internetland forever:p
  5. priuscatprimeguy
    2,730
    2,640
    No, it's plugged in until I leave:D
  6. DavidA
    2,349
    1,825
    Chicago western burbs
    I've not run into unexpected ICE firing up yet, except for once on a 30 degree night with the heat pump on at 74 degrees (too high) and the fan at level 5 (higher than normal), and charge level down to 9%. To me that was understandable as probable engine preconditioning. Didn't like it, but boom, there it was.
    One week from now the high will be 18 and the low 8 degrees. I'm about to find out the lower limit of EV usage. Car will be left out (no garage) for more than 8 hours with various levels of charge, and unplugged. I usually don't have the heat turned on for my 1.5 mile trip to work. Maybe even turning the headlights or the radio on will be enough to trigger the ICE? Slowly decreasing temps until then.
    Besides the lower temp tests in my normal usage, I might try the cruise control theory when it isn't 8 degrees. Note: at 8 degrees F the ICE should start anyway - or anything below 14, according to the manual.
  7. Thing is, if the outside temperature goes below 14F and you need the heater, then the engine will turn on (page 87 of the manual). Of course, I would also expect that below this temperature, less current draw is available from the battery, so the engine may turn on. Perhaps this is an ideal opportunity to use Charge Mode so that gas is put to some use on very cold mornings, and then use electric on the way home. (Your mileage may vary, as they say.)
  8. priuscatprimeguy
    2,730
    2,640
    early this year around January or February the temperature was 7 F and ICE did in fact come on, which I expected because it was below 14 F. I'm just concerned when it's below 50 F and above 20 F that ICE is coming on unexpectedly.
    HPrimeAdvanced and bwilson4web like this.
  9. DavidA
    2,349
    1,825
    I'm thinking that freezing temperatures, lots of snow buildup, shoveling a path in the driveway, scraping ice off the back window and windshield is an excellent opportunity for Charge Mode usage. It can take 10 minutes or more to do those chores before driving off. The weather isn't at that point here yet, but give it a couple more weeks and I'll put full time EV mode behind me for the duration.
    The L2 charge cable, which is outside, is already getting mighty stiff to move from the coiled storage position in these 20-30 degree cold night nights. I can't yet imagine what it will be like at 0 degrees F. Or I might not have to imagine since I'll be in HV mode 100% of the time.
  10. bwilson4web
    16,537
    Replicated the symptom the third time and captured on dash cam:
    1. Fully charged and cold soaked at 40-41F (4-5C)
    2. Was parked back ended, drove straight away, heater off
    3. Several max accelerator and two stops
    4. Accelerated to ~50-52 mph
      1. Use "," and "." to back or forward a frame
    5. 1:47 -> Cycled cruise control: ON-SET-OFF (accidental OFF)
    6. 1:49 -> Still in EV when hit SET and OFF (accidentally)
    7. 1:54 -> Cycled cruise control: ON-SET
    8. 1:57 -> Engine starts and runs, the heater was off and stayed off
    Engine stopped about 5 miles down the road on its own. The heater did not come on by itself.
    #830 bwilson4web, Dec 6, 2017
  11. priuscatprimeguy
    2,730
    2,640
    So it looks like cruise control is the culprit. I'm trying to stay off cruise but it's SO HARD!!!! my right finger is just itching to touch the set button on the stalk and pushing down on it afterward.:p
  12. bwilson4web
    16,537
    We really need to do A-B-A testing with enough samples to say ... 'we got it.'
    It would help if others can replicate our results so we can map out the limits ... temperature, early operation (does backing out inhibit the symptom,) e.t.c. We really need a rock solid way to replicate the problem so we can document and teach Toyota how to do it too.
  13. Lee Jay
    5,850
    4,036
    I use cruise control constantly, and I've never had this happen. I'm rarely at full-throttle, however. I suspect that was the culprit here, but not in the original case because it happened at almost no throttle.
  14. A Prime Factor
    A Prime Factor Formerly "I want my PHEV"
    340
    171
    Madison, WI
    Good work, Bob! Yes, we definitely need repeated A-B-A testing. People here on this thread don't seem to know much about problem solving (it's okay, most people in general suck at it). You can't just take it to the dealer and expect them to fix it. It is impossible to fix a problem that you cannot reproduce. They know that. They know that they do not have enough data. We are closing in on it here, though. Let's keep it up.
    It's more than just cruise control, though. The formula seems to involve quite a few aspects, and something you are doing (or not doing) is still different from @priuscatprimeguy. We haven't found what that is yet.
    You need to do what makes the ICE come on so we can be sure. I'm guessing you used cruise control with the rental car, no? If so, continue using the cruise control as you always do. Do it for two days in a row to be sure. Then try not using CC without changing anything else.
    Anyone else who wants to attempt to reproduce the event needs to try to make as close to the conditions @bwilson4web and @priuscatprimeguy had. Make sure it's cold enough, below 50F. Park outside, overnight, plugged in, fully charged. Back in, so you drive straight out forward (I've been wondering for a few weeks if this might be critical) right away. In EV with heat off. Little or no hills (let's not introduce that variable if we don't have to). Speed up to at least 35mph within the first couple of minutes. Use cruise control.
    Unfortunately, in spite of living in the appropriate climate, I am not able to try to reproduce this myself, for several reasons.
    1. I park in my garage,
    2. I drive in forwards and back out,
    3. I live in a hilly area,
    4. I have to drive quite a ways before I can go fast enough, even farther if I want a non-hilly place to speed up, and most importantly,
    5. I do not (yet) have a Prime
  15. priuscatprimeguy
    2,730
    2,640
    yup, that is a big reason:eek:
    bwilson4web and HPrimeAdvanced like this.
  16. bisco
    52,863
    i thought you stated the ice has also come on in the past without cruise.
  17. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    Details, details, details!!
  18. priuscatprimeguy
    2,730
    2,640
    I have done the ICE coming on while using cruise control for awhile now, so I'm going to do the without cruise control first for now, we have about two weeks of temperatures below 50 F so there's plenty of time to do this investigation.:cool:
  19. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    I think we'd better call you Mr. Columbo, from now on!! Oh, and just one more question....!!
    Stubborn Sleuth; Dedicated Detective!
  20. priuscatprimeguy
    2,730
    2,640
    It's been almost a year and I think my Alzheimer's is kicking in so I could be wrong about ICE kicking in while NOT in cruise control mode, that's why I'm doing the "without cruise control" now:D
    bisco and HPrimeAdvanced like this.
