ICE comes on anyway
Discussion in 'Prime Main Forum (2017-2022)' started by priuscatprimeguy, Feb 26, 2017.
  1. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Okay, looks like my test is on for tonight (didn't work out last night). Parked outside at 4:30pm, 36°F, plugged in with charge timer set for 6:30am tomorrow morning. The prediction is for the temperature to gradually decrease to 21°F by tomorrow at 7am. I plan to leave for work around 6:30am meaning it will be cold soaking in an average temperature of something close to 25°F for 14 hours before I do.
    52,863
    you folks are going the extra mile for pcpg!
  3. Lee Jay
    5,850
    4,036
    Mixed results. It was 16°F on the car temperature sensor when I got in. I used heat the whole way, tried with and without cruise control, climbed a 12% grade at 40mph, accelerated from 0 to 55 up a 7% grade, engine never started. However, the cold really sapped my battery efficiency. I usually get to work with about 40% battery remaining (11 miles climbing 700 feet). This time I was on the final hill (6% grade, 55mph) and when the battery dropped to 16%, the engine started. Outside temperature read 19°F at the time.
    Since I've never climbed that hill with that battery that far depleted, I don't know if that's unusual or not.
  4. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    did you drive off immediately after you put the car in READY? Because if you had heat running in the car for five minutes or so, ICE will not come on.
    HPrimeAdvanced likes this.
  5. I'm wondering if your engine turned on because of the limited current draw going up the hill and/or passing someone when outside temperatures get too low. How high up was the "arc" on your HUD when the engine turned on?
  6. bwilson4web
    16,537
    I was able to replicate it again this morning. My goal was to confirm it is not turning on cruise control but setting, down-pat, that triggers the engine-ON event.
    Preconditions:
    • 41F (5 C) - cold soak
    • 100% SOC - over night
    • 44-45 mph - speed
    • max accelerator - several times
    • two stops
    Tomorrow, I will test if we can get the engine-ON symptom with 70-80% SOC. The reason is I can park the car, after hours, at the local Toyota service center with 80% SOC so it can cold-soak over night. Then we can replicate the symptom with them driving the car.
    My priority is to get a trouble ticket into Toyota that is escalated through their system. For good measure, file a problem report with the EPA/NHTSA documenting this fuel economy problem.
  7. priuscatprimeguy
    2,730
    2,640
    After I dropped off my rental car back to the dealer ship I think it was below 50 F that day when I drove my car home, it is about 2.0 miles from home to the dealership and I fully charged my car before I dropped off my car to pick up the rental car. My car sat in the lot for four days. When I went home ICE did not come on.
  8. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    17 F this morning. Engine never started on my commute.
  9. jaqueh
    jaqueh Active Member
    341
    199
    San Francisco
    Mine came on the other day going downhill, no defrost, interior set to 70°, outside 50°, but battery showed 3 miles of range left so about 1% left.
  10. priuscatprimeguy
    2,730
    2,640
    and the criteria for your findings?
    1. car outside overnight
    2. activated cruise control
    3. did not sit in car while climate heated inside of car for 5 minutes or so.
  11. john1701a
    12,840
    5,312
    58
    I filmed it, so detail on the way...
    1. Garaged with "Climate Prep" selected on the scheduled recharge.
    2. Never. I only use cruise for cruising on the highway.
    3. Nope. I drove away immediately.
  12. priuscatprimeguy
    2,730
    2,640
    I understand. It was 28 F here this morning. I had climate off and did not activate cruise control and ICE did not come on for me either:D
  13. priuscatprimeguy
    2,730
    2,640
    interesting, a bit off topic, but the dealership out in Idaho Falls Idaho ( when I took my trip out west I stopped there for my 5k) said there's a new Map update available. They want me to call their parts department for details. Funny, why didn't my local dealership notify me?
  14. bisco
    52,863
    there is a map update thread.
    dealerships are not required to call about map updates, it is not a free service.
    the idaho dealer is more proactive in marketing apparently.
    read the other thread before updating, there is some question as to what is the latest version.
  15. priuscatprimeguy
    2,730
    2,640
    yup, I knew that:p gee, maybe I should make a road trip out of it?:eek: but, since my map is a year old, the gps may not get me there?:eek:
  16. john1701a
    12,840
    5,312
    58
    btw, I had the usual setting off 65 ECO with driver-priority.
    priuscatprimeguy likes this.
  17. priuscatprimeguy
    2,730
    2,640
    https://priuschat.com/search/52352712/?q=map&o=relevance&c[node]=158
    pick one @bisco
    instead of saying "there's a map update thread":rolleyes:
  18. bisco
    52,863
    sorry: 'navigation map version' posted by member; dennis_ma.
    #858 bisco, Dec 7, 2017
  19. priuscatprimeguy
    2,730
    2,640
  20. bisco
    52,863
    what is 'copy and paste'? i must be.:oops:
