ICE comes on anyway
Discussion in 'Prime Main Forum (2017-2022)' started by priuscatprimeguy, Feb 26, 2017.
  1. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    I see that it's 32 F right now in Huntsville Al. so get out there!:p
  2. A Prime Factor
    A Prime Factor Formerly "I want my PHEV"
    340
    171
    Madison, WI
    So, wait, you accelerate and engage cruise control at the same time? My normal use of cruise is
    1. Accelerate to desired speed.
    2. Activate/set cruise control.
    3. Adjust if necessary.
    "Hey, Car. I'll show you how I want you to drive. Now you do it."
  3. bwilson4web
    16,537
    I'm not ready to do low temperature range testing, yet. In engineering, we like to hold constant as many variables as possible and only range test one. Speed is something the driver can control but temperature is for most of us, outside of our control.
    pilotgrrl likes this.
  4. priuscatprimeguy
    2,730
    2,640
    :p:LOL::ROFLMAO::D:eek::eek::eek:!!!!!
    No silly! If you watch my videos you'll see I drive out of my parking space at 5 or 10 MPH for about 0.2 miles then turn left, or right, depending where I'm going down 14 mile road, then accelerate up to 35 MPH, set cruise and BAM! ICE kicks in:mad:
  5. priuscatprimeguy
    2,730
    2,640
    so what temperature are you gunning for?:confused:
  6. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Cruise was the unexpected element in the equation.
    Normally, it is used for highway driving. With just a 25-mile EV capacity and a high probability of soon driving faster, engagement of that mode is instructing the system to be ready for more power to be demanded. So, it fires up the engine in preparation for that.
    It's another easy-to-explain situation that took us a great deal of time to insolate detail for.
    That's what we do as first-year owners.
    A Prime Factor likes this.
  7. bwilson4web
    16,537
    Anything between 38-44F. My 50F failed and others have reported problems replicating in freezing weather.
    If we can do an early cruise control ON that defeats engine ON at any subsequent speed, we'll have a great workaround.
    priuscatprimeguy likes this.
  8. A Prime Factor
    340
    171
    Madison, WI
    Forgive me for taking what you said literally.
    Still trying to come up with the exact formula so others can replicate.
  9. priuscatprimeguy
    2,730
    2,640
    t seems to be my consensus that driving immediately, accelerating to a speed of 35 MPH while engaging the cruise control.
    yes, I can see where what I said can be misleading, sorry
  10. priuscatprimeguy
    2,730
    2,640
    I see your point, but only if outside temperature is below 50 F
  11. john1701a
    12,840
    5,312
    58
    Correct. It's just part of the chemistry... like how electric-resistance increases significantly when the battery-temp is lower than freezing... hence the addition of a battery-warmer to keep it from falling below 32°F.
  12. A Prime Factor
    340
    171
    Madison, WI
    Okay, now that we have that straightened out, do you want to try some more tests to see if we can find another workaround? So far, we have
    • Drive at slower speeds for first 5 minutes
    • Wait 5 minutes before driving off
    • Don't use cruise control
  13. priuscatprimeguy
    2,730
    2,640
    the battery warmer, in my case made no difference, ICE still kicked in when Cruise was activated.
  14. priuscatprimeguy
    2,730
    2,640
    That may be misleading, I would drive down the side streets that have a speed limit of 25 MPH. Since Cruise activates at 28 MPH, I never got a chance to see of ICE kicked in or did not kick in due to the 25 MPH speed.
  15. A Prime Factor
    340
    171
    Madison, WI
    Yes. But I think "5 minutes or so" might be a factor.
  16. priuscatprimeguy
    2,730
    2,640
    correct:D
    Edit: that five minutes is with climate set to 65 ECO and on. I haven't tried it with climate set to off.
    HPrimeAdvanced likes this.
  17. A Prime Factor
    340
    171
    Madison, WI
    Do you want to try my other suggestion of drive off immediately, but park on the side street for 5 minutes before driving 35mph?
  18. priuscatprimeguy
    2,730
    2,640
    with climate on, or off? and engage cruise? or no?:D
  19. A Prime Factor
    340
    171
    Madison, WI
    Engage cruise. Climate at whatever you would normally do when driving.
  20. john1701a
    12,840
    5,312
    58
    Yes. We have several different scenarios overlapping. ICE will kick in regardless, it's like an override.
    Remember the 35 mph limit with PiP in the winter? That only applied when the pack was sitting outside in temps below 20°F. Speed came into play in that case.
