ICE comes on anyway
Discussion in 'Prime Main Forum (2017-2022)' started by priuscatprimeguy, Feb 26, 2017.
  1. dalcon95
    dalcon95 Senior Member
    512
    653
    Easley, South Carolina
    Same with me. I can drive strictly in EV only with no ICE. I don't turn on the Front defrost. I have it in ECO and EV mode and no ICE. I drive about 21 miles one way in all EV. If I need a strong front defrost, I use the Prime app while it is plugged in and turn on the heat and defrost on hot before I get to the car so I have no need for defrost while I drive, which would kick the ICE on. Sometimes when I have my windshield wipers on and the climate control on AUTO ECO setting, it will put the air flow to the front windshield and vents without the ICE. I am learning the tweaks without using the ICE.
    #1 in Easley,SC
    bwilson4web likes this.
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    you're in south carolina? what was the temperature when you embarked on your all EV journey?
  3. dalcon95
    512
    653
    In the mornings lately, it has been as low as upper 20's in the mornings to 60 or 70s during the day. I treat the front defrost button as the plague in order to keep the ICE from coming on and it works. No ICE. I always keep it in EV only mode and not EV AUTO mode. It is also hilly in the Upstate of South Carolina which is where I'm at.
    #1 in Easley,SC
    52,848
    we may never have a cold enough winter to ever do enough testing.
    bwilson4web and dalcon95 like this.
  5. El Dobro
    El Dobro A Member
    7,106
    3,282
    Works for me.
    priuscatprimeguy and dalcon95 like this.
  6. priuscatprimeguy
    2,730
    2,640
    Ok, here's the latest: When I approached my car the green led was lit in the charging port (charged battery 24 hours ago) Probably traction battery warmer. Temperature displayed on dash: 32 degrees F checked temperature on phone for Clawson Michigan 28 degrees F. Made my usual left turn onto 14 mile road accelerated to 35 MPH set cruise. got to Crooks road ( 1 mile away) turned right accelerated to 45 MPH turned right on 15 mile road accelerated to 40 MPH, turned right on Livernois accelerated to 35 MPH. slowed down to 25 MPH (speed trap in front of police station) turned right on 14 mile road and proceeded home. ICE did NOT come on, I repeat, ICE did not come on:D
    dalcon95 likes this.
  7. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
  8. priuscatprimeguy
    2,730
    2,640
    My conclusion is if the Traction Battery heater is between charges ( twelve hours between charges) and I'm unlucky enough to be before the next heating cycle then ICE will probably come on.:mad:
  9. priuscatprimeguy
    2,730
    2,640
    Although when I had ICE kick in was when I scheduled charging for 9 am with. Climate prep enabled
  10. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    I had the impression that the battery heater function purpose is to minimize the low temp hit on EV range and probably for battery health, but not to eliminate ICE firing at temps in the twenties and thirties while you still have EV range.
    - Battery heater can be cancelled altogether in setting by the owner.
    - PiP has no battery heater and ICE is not started at these temperatures.
    The problems you have encountered are not, IMO, battery heater related, and I think you should check what else you did differently in the last test?
  11. priuscatprimeguy
    2,730
    2,640
    I disagree completely about PIP ICE not starting at those temperatures both my 2012 and 2015 PIP ICE would kick in if outside temperature was 50 degrees or below, Remember my cars are outside ( not in a garage). Like I said in previous posts ICE kicked in when I scheduled departure time to 9 AM with Climate Prep enabled. I found that if I charge my Prime immediately when departing the car and then getting into my car the next day ICE would not kick in. I know how to turn off/on the Traction Battery heater.
  12. dalcon95
    512
    653
    I charge the traction battery immediately at plugin each time in the evenings, which might also effect the ICE not coming on in the mornings when it is in the 20s and 30s. I also leave it plugged in all night until I have to leave in the mornings at 6.
    #1 in Easley,SC
    priuscatprimeguy likes this.
  13. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Not mine and not everybody else's, AFAIK.
    Toyota recommends to use timer whenever possible and finish charging close to departure, it is much better for battery health.
    #93 giora, Mar 2, 2017
  14. priuscatprimeguy
    2,730
    2,640
    so, you know "everybody else?" did you take a poll?:rolleyes:
  15. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    I am saying based on reports in the PiP forum from 2012 to now.
  16. priuscatprimeguy
    2,730
    2,640
    ok, list them and remember if the car is housed in a garage it doesn't count, and I will need proof that the cars are in fact housed outside
  17. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Sorry, I should have said "non reports"(y)
  18. priuscatprimeguy
    2,730
    2,640
    you got proof of that?:D
  19. priuscatprimeguy
    2,730
    2,640
    #99 priuscatprimeguy, Mar 2, 2017
  20. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    We can go-on forever...
    My impression from your reports here is: either you have something wrong in your car (unlikely), or you do something 'incorrect' which forces the ICE. But I could be wrong.
