ICE comes on anyway
Discussion in 'Prime Main Forum (2017-2022)' started by priuscatprimeguy, Feb 26, 2017.
  1. Trollbait
    12,832
    The Volt has an engine maintenance mode to run the ICE after a period of time of no ICE use, and a fuel maintenance one to burn off old fuel. I believe the car gives a driver a warning about it happening.
    The PiP manual states how long on EV only it can go before the ICE is used for maintenance purposes.
    The Prime has to have similar.
  2. El Dobro
    El Dobro A Member
    7,106
    3,282
    Yep, the Volt asks if you want to run the EMM when you start, or delay it until the next start up. It usually happens after about 6 weeks of not using any gas.
    #1002 El Dobro, Jun 21, 2018
  3. DavidA
    2,349
    1,825
    Chicago western burbs
    I thought of that, and didn't mention that the day before it ran on HV mode for 10 miles. So that isn't it.
    bwilson4web likes this.
    52,895
    was the front defroster on?
  5. DavidA
    2,349
    1,825
    No, only the radio. I even had the front windows down to cool the car instead of the fan.
    Thought of this today. For charging the night before, I backed into the driveway with the nose to the street. The driveway, all 18 feet of it, is on a slight pitch upwards. Could the prime think it was traveling down a hill with the full charge, and decided to use HV instead? The downhill hypothesis has been brought up before, but that was mostly in much colder weather conditions.
    I'll also add that since the nose of the car is always pointing down the same driveway every time I've charged, and I almost always charge to full, and this has never happened before - always started in EV - that I don't consider this a very probable explanation. More likely the car just lost its mind for a spell.
  6. bwilson4web
    16,552
    See if you can replicate it.
  7. DavidA
    2,349
    1,825
    There's always that chance, but I hope it doesn't happen again. But still, charging to full and aiming downhill a little is how I always start off after loading up on electrons, so.... maybe.
  8. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    Interesting thing about the front defroster, I turned the front defroster on last night (it was 70 F) stayed in EV all the time. Go figure:confused:
  9. DavidA
    2,349
    1,825
    So, in one of the multiverses, the same you and in same Prime, their car went to HV. You were just the lucky one.
  10. priuscatprimeguy
    2,730
    2,640
    maybe my Prime became self aware and fixed itself:D
    HPrimeAdvanced likes this.
