ICE comes on anyway
Discussion in 'Prime Main Forum (2017-2022)' started by priuscatprimeguy, Feb 26, 2017.
  1. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    I will be repeating my test ( scheduling departure time for 11:00 AM on Saturday morning) with climate prep enabled. Saturday's temperature will be 17 degrees F in the morning with a high temperature of 36 degrees
    would you care to point out what I'm doing incorrectly?:D
    #101 priuscatprimeguy, Mar 2, 2017
  2. thatoneraccoon
    thatoneraccoon Active Member
    201
    146
    Ohio
    Got off work and it was colder than when I went in and its snowing. Temp is 33 via the prime. the prime sat outside all day at work and not plugged in. drove home all the way on EV. my top speed going home was only 45 this time because of traffic.
    Next stage of my experiment, I left it parked in the driveway unplugged. its suppose to be in the 20's tonight. will report my finding tomorrow.
    bisco and priuscatprimeguy like this.
  3. thatoneraccoon
    201
    146
    Ohio
    Well completed my next experiment. Left prime sitting out all night long, unplugged this time.
    Today I was actually expecting my ice to fire up. It was freezing, cold, 24F, prime covered in ice and snow. Didn't run the heater until after the hill, but it punched it again and took it too 60. Ice never came on. I turned on heat to auto after that cause I was freezing lol. Still ice never came on.
    So now I wonder just how cold does it have to be for the ice to come on?
  4. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Below 14F if you want heat.
  5. thatoneraccoon
    201
    146
    Ohio
    That's awesome and interestingly my Volt is 14F as well. But it doesn't matter if you have HVAC on or off or moving or sitting still. Once that temp display goes from 15 to 14 that ice fires up. So it's cool to hear that if I suffer freezing I could continue to drive gas free in the prime :D
    dalcon95 and priuscatprimeguy like this.
  6. Lee Jay
    5,850
    4,036
    You can still have seat and steering wheel heat in the Prime below that.
    thatoneraccoon and dalcon95 like this.
  7. priuscatprimeguy
    2,730
    2,640
    also ECO heat from the heat pump
    dalcon95 and thatoneraccoon like this.
  8. Lee Jay
    5,850
    4,036
    Really? The manual says you can't.
  9. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    You mean: warming to hear...:cool:
    Prodigyplace and thatoneraccoon like this.
  10. priuscatprimeguy
    2,730
    2,640
    since ICE kicks in below 14 degrees it's a moot point, I meant to say ECO heat works above 14 degrees F
    dalcon95 likes this.
  11. thatoneraccoon
    201
    146
    Ohio
    So I wonder just how cold can you get, even with HVAC off, can the prime go before it fires the ice
  12. Lee Jay
    5,850
    4,036
    I strongly suspect that will depend on how cold the battery is, not how cold the ambient air is.
    thatoneraccoon likes this.
  13. thatoneraccoon
    201
    146
    Ohio
    I wonder what temp that would be
    Man I so wanna take my car apart and look at the battery and see how they did things :D
  14. El Dobro
    El Dobro A Member
    7,106
    3,282
    The ICE comes on in the Volt at 14F to protect the battery and keep its efficiency up.
  15. bisco
    52,880
    in the pip, you can drive slowly on flat ground for awhile, the battery will warm and then you can drive faster and harder, even down to zero degrees in my experience. but if one little thing goes awry in the beginning, the ice fires. but it doesn't automatically come on, like the lift back.
  16. thatoneraccoon
    201
    146
    Ohio
    Indeed I understand why and it didn't bother me that much and it wasn't that often it was 14 or below so it only happened to me probably 20 times turning the whole time I owned it.
    But if the volt was doing it, why not Toyota. Also the volt had in my opinion a better battery management system with the liquid thermos. Now that there is all that. What does the Bolt do when it's 14F or cooler?
    I would have liked to have an option if to run the ice or not on my volt at 14
  17. priuscatprimeguy
    2,730
    2,640
    welp, I left my car unplugged last night. Went to Sams Club this morning. Dashboard Temp: 26 degrees F outside temp on phone in Madison Hts MI. 22 degrees F. Max speed traveled 35 MPH. wait for it............... ICE did not kick in. So I was WRONG! sue me! lol, but one last test tomorrow morning I have scheduled departure time to 11 AM with climate prep enabled, (back to the scene of the crime):D
    dalcon95, thatoneraccoon and giora like this.
  18. El Dobro
    El Dobro A Member
    7,106
    3,282
    If you want to, just do like the guys on the Volt Forum do and fool the sensor.
  19. priuscatprimeguy
    2,730
    2,640
    pity the fool (the sensor):p
  20. thatoneraccoon
    201
    146
    Ohio
    Well glad it's working right. :) Atleast ya got something to compare with.
    Also I didn't use the climate prep or anything. I went for worst case
    priuscatprimeguy likes this.
