ICE comes on anyway
Discussion in 'Prime Main Forum (2017-2022)' started by priuscatprimeguy, Feb 26, 2017.
  1. dalcon95
    dalcon95 Senior Member
    512
    653
    Easley, South Carolina
    Possibly
    #1 in Easley,SC
  2. dalcon95
    512
    653
    Going by my experience, as long as you turn on the ECO mode for the climate control, it will stay that way until you purposefully turn it off.
    #1 in Easley,SC
  3. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    good to know, thanks #1 in Easley, SC ( #1 in Clawson MI):D:cool:
    dalcon95 likes this.
  4. priuscatprimeguy
    2,730
    2,640
    Yup, always, so if you're going to comment about something is wrong with my car and your car is sometimes out in the cold not in a unheated garage or sometimes in a unheated garage but mostly sits outside don't bother. I only want to hear from people who have their Prime outside in 20 to 30 degree weather or colder. I drove my car to work today this morning 28 degrees climate was off front defroster off seat heaters off steering wheel heaters off. ICE kicked in at 35 MPH. I'm going to discontinue testing my car at speeds higher than 25 MPH for the first 1.5-2.0 miles because that's what it takes to keep ICE off.:mad:
    thatoneraccoon likes this.
  5. bisco
    52,803
  6. priuscatprimeguy
    2,730
    2,640
    well, if he did he failed the test:mad:
    thatoneraccoon and bisco like this.
  7. thatoneraccoon
    thatoneraccoon Active Member
    201
    146
    Ohio
    Yep I tested all this. Left car sit outside exposed for 3 days.
    If I recall correctly, it was low 20's sat outside overnight, got covered in ice and snow. Left unplugged but full charge overnight to test leaving car plugged in changed anything in testing.
    My test on route to work, I left climate off. Used only heated seat. I was hard on my prime, I tried to get ice to fire, I had no luck. I floored the pedal to took it to 60mph even, ice never came on. This was about 1/2 mile from my house. I did not pre heat or start car. Just hit power and went on my way
    On way home from work was upper 20's used climate on eco set at 74. Also drove hard. Ice never came on.
    It was 18 the other day here and was on the freeway at 75mph and ice never came one.
    So far in everything I have done and tried, the ice has never came on in my prime tests or regular usage, unless I changed to EV auto or ran out of charge or used defrost.
    bisco and dalcon95 like this.
  8. bisco
    52,803
    is this conclusion out the door now?
  9. dalcon95
    512
    653
    I know this isn't the case being I personal have driven over 800 miles and not use a drop of gas.
    #1 in Easley,SC
  10. thatoneraccoon
    201
    146
    Ohio
    I've heard that there is an interval, but I don't know what it is our how it's tracked. I wonder if there is any notification like the Volt? Mine would fire the ice about every 3 months if I didn't use the ice. And it would pop up a display notification saying "engine maintenance mode"
  11. dalcon95
    512
    653
    It would be a challenge to test that out for 3 months or even longer.
    #1 in Easley,SC
  12. thatoneraccoon
    201
    146
    Ohio
    Indeed, I think I'm going to start keeping track of this and see
  13. priuscatprimeguy
    2,730
    2,640
    yup, he's doing something wrong, because ICE kicked in for me today, one thing I did notice, I scheduled charge for a 7:00 am departure and it completed at 7:00 am even though I have not reset daylight saving time on the system clock. (should have completed at 8:00 am not 7:00 am) also when I left for work at 10:00 am the green charge light was lit in the charge port door. When I got into the car the car indicated to me that charge had not quite finished. (possibly the Traction Battery warmer?)
  14. priuscatprimeguy
    2,730
    2,640
    only problem to this theory is by April the weather will have warmed up to make the test unfeasible.
  15. priuscatprimeguy
    2,730
    2,640
    I drove the car past the EV miles allotted on my car yesterday, so engine maintenance was performed yesterday and was not due for another
  16. Tideland Prius
    16,674
    Was there a message on the MID that said it was in engine maintenance mode?
  17. dalcon95
    512
    653
    So the engine maintenance mode on the Volt is for low temperatures, or for the lack of ICE activity, or is it for the gas sitting to long?
    #1 in Easley,SC
  18. priuscatprimeguy
    2,730
    2,640
    no, but the interval between when ICE comes on every 200 miles of all EV driving (124 miles on the 2012-2015 PIP) was not reached because I drove the car past the 22 miles of EV I had yesterday so the ICE was "exercised" yesterday.
    That would make sense if not for the fact when I drive down streets at 25 mph for 1.5-2.0 miles ICE does not come on even after I speed up to 35 mph afterwards. For at least 200 miles (time of travel of several small EV trips adding up to 200 miles)
    #158 priuscatprimeguy, Mar 12, 2017
    Tideland Prius likes this.
  19. priuscatprimeguy
    2,730
    2,640
    I was already to thrown in the towel and you guys were right when, for several trips that I made, ICE did not fire, but the weather was not as cold as it was this morning (not 14 degrees cold, more like 28 degrees cold)
  20. El Dobro
    El Dobro A Member
    7,102
    3,282
    Lack of ICE activity. The ICE started in my Volt last night 'cause I haven't used any gas for some time.
    dalcon95 and priuscatprimeguy like this.
