ICE comes on anyway
Discussion in 'Prime Main Forum (2017-2022)' started by priuscatprimeguy, Feb 26, 2017.
  1. dalcon95
    dalcon95 Senior Member
    512
    653
    Easley, South Carolina
    How does that temperature supposed to effect engine maintenance mode when it comes on for the lack of use of the ICE? Should be able to keep the engine from running for 3 months or more by keeping the parameters set to prevent the ICE from running for any temperature above 14 degrees. Should be able to test for engine maintenance mode for any time of the year.
    #1 in Easley,SC
  2. thatoneraccoon
    thatoneraccoon Active Member
    201
    146
    Ohio
    It was maybe half mile from my driveway to when I floored my prime and took it to 60. No ice here
    52,818
    i think we're confusing engine maintenance mode, and ppg's problem with the ice firing early in his commute on cold days.
    dalcon95 likes this.
    52,818
    this is strange, because the 200 mile interval has been mentioned quite a few times on priuschat. i think lee jay posted the o/m page, but not sure. the pip fires very 124 miles. it's to move gas through the engine before it gets stale and clogs something.
  5. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    No, I've never found a written reference to that. One of the others heard it from Toyota (Japan, maybe?) and mentioned it here.
    Because of the lack of a written reference, I can't confirm that it's true.
    priuscatprimeguy, dalcon95 and bisco like this.
  6. bisco
    52,818
    interesting. if it's definitely not in the manual, maybe they left it off. that would be great.
  7. dalcon95
    512
    653
    I have driven with no ICE on, which I can tell if it is running, and no change in my gas miles to empty on the dash, which backs up my claim. I personally haven't experienced the "engine maintenance mode", which is when the engine spontaneously starts because of the lack of running. I have experienced the ICE coming on being out of the parameters of keeping it in EV only. I am going to try my best to try to go months without purposely using the ICE to see if there is a such thing as a "engine maintenance mode" on the Prime. We will see.
    #1 in Easley,SC
  8. bisco
    52,818
    that would be great. i don't like the feature, but understand why mfg.'s don't want to deal with problems of people who want to use their phev as a bev.
  9. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    true, only ICE is coming on because of the cold weather not because of engine maintenance. I can live with the engine coming on every 200 miles.
  10. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Cold weather should not trigger the ICE
  11. priuscatprimeguy
    2,730
    2,640
    and yet, it is @giora
  12. Lee Jay
    5,850
    4,036
    In your car. In others', it's not. I still suspect a fault.
  13. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    @priuscatprimeguy reported the same occurrence at the same place with his two PiPs also.
    I suspect starting the ICE to prevent regeneration of a full battery.
  14. priuscatprimeguy
    2,730
    2,640
    I'm still waiting for someone who has their car parked outside ALL THE TIME with no visits to their unheated garage. Then we can talk.
    so, everybody else does not have their battery fully charged?
    #174 priuscatprimeguy, Mar 13, 2017
  15. Lee Jay
    5,850
    4,036
    Seems like that bridge has been crossed.
  16. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    They do, only they do not start driving from your home on your route.
  17. priuscatprimeguy
    2,730
    2,640
    so three days is enough time? Mine's out there all the time since November 30 th
  18. priuscatprimeguy
    2,730
    2,640
    my route?
  19. Lee Jay
    5,850
    4,036
    More than enough. The thermal time constant is on the order of an hour.
  20. priuscatprimeguy
    2,730
    2,640
    I guess we'll never get a straight answer based on your assumptions
