ICE coming on first thing in the morning
Discussion in 'Prime Main Forum (2017-2022)' started by Captmiddy, Jan 7, 2017.
  1. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    Thanks, I'll try that and get back to you:D
    51,948
    yes, that makes sense. impossible on a test drive with an uneducated salesman.
  3. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Educated enough to find "power" button eyes closed...
  4. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    Dang, I'm glad I live in Austin (TX)!
    That is, until the >100F summer hits...
  5. priuscatprimeguy
    2,730
    2,640
    Like I said I told you I will try that and get back to you. Well I tried it got the "i" got up/down but no hybrid system indicator (except for the picture of the car with the battery wheels and engine in it) Turned HUD off same results no Hybrid system indicator like what shows up in the HUD.:confused:
  6. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Have you selected "i" before going up/down?
  7. priuscatprimeguy
    2,730
    2,640
  8. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Did you have it in drive? I don't think it shows in park.
  9. bisco
    51,948
    really? that is an odd way to go about selecting a screen. is there a lawyers warning, 'cannot be selected while parked safely'?
    priuscatprimeguy likes this.
  10. priuscatprimeguy
    2,730
    2,640
  11. Lee Jay
    5,850
    4,036
    You don't have to be moving, and displaying a screen about your current throttle setting doesn't make a lot of sense when you're in park.
  12. bisco
    51,948
    it displays on the pip. you're probably right, they probably changed it cause it made no sense. make them put it in drive, then look for it, much better. i bet they're chuckling.
  13. Lee Jay
    5,850
    4,036
    When i is selected, the following information can be displayed by
    pressing [up or down arrow] of the meter control switches.
    ● Energy monitor (→P. 208)
    ● Hybrid System Indicator (→P. 210)
    ● “Fuel Consumption Record” (→P. 218)
    ● “Drive Monitor” (→P. 221)
    ● “Drive Monitor 2” (→P. 222)
    ● “Eco-Diary” (→P. 223)
    Are you saying it doesn't scroll through those when you hit the up and down arrows? It worked on both of the Prime's I test drove.
  14. bisco
    51,948
    hybrid system indicator is the one. hsi.
  15. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    HSI is on the MID, you can also have a (simpler) version of the HSI as a sub-screen of the main screen (speedometer screen).
  16. priuscatprimeguy
    2,730
    2,640
    When I scrolled up/down I got everything you said except for the hybrid system indicator that normally shows up in my HUD display, it's possible that since it's on my HUD that it won't show up on the dashboard
  17. ssdesigner
    ssdesigner Active Member
    304
    241
    california
    2013 Aqua
    I have a suspicion that 50 degrees is the cutoff. My indoor parking garage is normally around 50, and with heating off the ICE still starts on startup. This morning it was 55 in the garage.....no ICE at startup. Driving outside the ICE fired up as soon as the temp gauge showed 50 degrees.
    Just a thought.
  18. priuscatprimeguy
    2,730
    2,640
  19. bisco
    51,948
    this is a prime thread. the software is different than lift back.
  20. priuscatprimeguy
    2,730
    2,640
    Yup, agreed, I found that to be the case when I had 2012 and 2015 PIP
