ICE coming on first thing in the morning
Discussion in 'Prime Main Forum (2017-2022)' started by Captmiddy, Jan 7, 2017.
  1. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    Also true for the Prime bisco
    51,947
    what is true?
  3. priuscatprimeguy
    2,730
    2,640
  4. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    I'm pretty sure it can be in both places because I think it was in my second test drive.
  5. priuscatprimeguy
    2,730
    2,640
    Well I'm still waiting for a solution, so far I'm not seeing any
  6. bisco
    51,947
    both your pips and your prime start the engine under 50 degrees?
  7. Lee Jay
    5,850
    4,036
    ■When operation of each function stops
    ●The Hybrid System Indicator stops operating in the following situations.
    • The “READY” indicator is not illuminated.
    • The shift position is not D or B.
    Are you looking at the MID? The only other thing I see is the ability to turn off the MID in meter customize.
    giora likes this.
  8. Tom_06
    Tom_06 Active Member
    609
    142
    Newark, Delaware, USA
    Heater is on Auto, 72F
    My Prime Advanced has never started the ICE until the EV portion of the battery was depleted or I manually switched it to HV. That is in weather from 65 F a few days ago all the way down to 9 or 10 F. Mostly I am leaving from a garage that stays above freezing, but one morning it was at 28 F. It includes parking outside for an hour or two before starting the car to return home. The 9 or 10 F day it was parked outside for an hour.
    I only have three weeks and 300 miles experience. Heater is on Auto, set to 72 F, have used both regular and Eco mode for the heater. Nearly 100% of the car's operation has been on EV. I just don't know what I am doing wrong.
    giora and bisco like this.
  9. priuscatprimeguy
    2,730
    2,640
  10. priuscatprimeguy
    2,730
    2,640
  11. bisco
    51,947
    a picture is worth a thousand words.
  12. bisco
    51,947
    wow, never heard of that before.
  13. priuscatprimeguy
    2,730
    2,640
    Maybe you have not been paying attention, because I mentioned this about ICE kicking in a couple of times
  14. Lee Jay
    5,850
    4,036
    Multi-information display. The display on the right of the one with the speedometer on it.
  15. Tom_06
    609
    142
    Just looked at mine. The HSI is two up from the "Drive monitor 1 display" ("From Start" is what I have set). It is dimmed but visible even in Park or Neutral and can be selected in Park or Neutral. It comes up to full brightness when Drive is selected. My HUD is on with the similar indicator and EV miles displayed. The car says it is 38 F in the garage. No ICE came on.
  16. priuscatprimeguy
    2,730
    2,640
    OK, it's working fine now, I could've sworn I tried it in drive, apparently I didn't have hsi selected when I was in drive
  17. priuscatprimeguy
    2,730
    2,640
  18. bisco
    51,947
    yes, but 49 outside is warmer than 38 inside a heated garage.
    priuscatprimeguy likes this.
  19. bisco
    51,947
    a distinct possibility.:oops:
    #99 bisco, Jan 20, 2017
  20. priuscatprimeguy
    2,730
    2,640
