ICE coolant replacement question
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ryan Will, Jun 18, 2022.
  1. Ryan Will
    Ryan Will Member
    68
    43
    Southern California
    Hello all,
    Long time viewer, first time poster here.
    I’m looking for some guidance on a potential issue:
    Yesterday, I did a coolant replacement for both the ICE and the inverter, as well as replaced the water pump and thermostat (all very easy jobs, just time consuming… and used genuine parts for everything).
    I followed several procedures on YouTube and here about bleeding the system, and each procedure states the radiator fans should turn on several times during the bleeding process while in maintenance mode.
    My fans never turned on, even after almost an hour of idling and reving the engine in maintenance mode. Also used an OBD reader to check temperature and never saw the temperature get above 200°F.
    Also took the car out for a test drive, checking the temperature the whole time, and still seemed OK. I was able to see coolant circulating in the reservoir during idle, as well.
    So, long story short, I am hoping the fans not coming on while bleeding is a problem. I can confirm the fans do turn on if the AC is on, and the heater works perfectly. Any thoughts from the community on this?
    For reference, I have a 2015 Prius Three with almost 120,000 miles and haven’t had any issues thus far.
    Thank you!
  2. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    The cooling fans will come on when the engine coolant temp passes a certain point. Not sure what that number is, but if you’re genuinely concerned about cooling fan functionality, there is a way to activate it using tech stream.
    If you idled the vehicle in inspection mode for that long and both radiator hoses are getting hot (meaning thermostat has opened), you should be ok.
  3. Ryan Will
    Ryan Will Member
    68
    43
    Southern California
    Thanks for the insight. I did check the hoses and they definitely were hot and I even squeezed them per another PDF that was posted on this forum at some point.
    Took it out in the freeway today for about 45 minutes, and so far so good. I’ll obviously just keep checking on it the next few days. The only thing is that I did slightly overfill the reservoir initially. Not terribly so, but I may siphon some out to be safe.
  4. Mendel Leisk
    42,264
    When I did the engine coolant change, I ran the engine in maintenance mode for close to half an hour, fans never came on, all was fine though.
  5. ASRDogman
    ASRDogman Senior Member
    8,042
    4,075
    An hour??? Wow!
    Both times I did mine, I filled slowly, and just let it run at a normal start. It stopped
    after about a minute. Filled the reservior and then drove it. Check it afterward and
    then the next morning. I checked it after I drove it for a longer drive, and it was
    at the mark. And 10,000 miles later it's still at the same mark.
  6. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,559
    2,599
    Taylors, SC
    I used the UView vacuum coolant filler. Took 15 minutes and no need for the fidgety maintenamce mode.
    Since I got mine, Harbor Freight has come out with a less expensive model.
  7. ASRDogman
    8,042
    4,075
    That's not a Prius..... And it's still easier to fill it slowly....
  8. Georgina Rudkus
    3,559
    2,599
    Taylors, SC
    Worked on a Gen 3, which has the thermos and a nore complicated procedure.
  9. ASRDogman
    8,042
    4,075
    Not a Gen3 Prius. That's the one people seem to have a problem with.
    Again, it's still easier to fill it slowly....
  10. Georgina Rudkus
    3,559
    2,599
    Taylors, SC
    Doggie. My Gen 3 was absolutely easy to fill with the UView.
  11. ASRDogman
    8,042
    4,075
    rude kus, my Gen 3 was absolutely easier to fill by pouring slowly.
    Both times. And it was a LOT quicker, easier, and cost nothing!
  12. Ryan Will
    Ryan Will Member
    68
    43
    Southern California
    I had no issues with the whole maintenance mode thing, but was just concerned that my fans never turned on…. Every procedure I watched or read said the fans are supposed to turn on, but again mine just never did. Not sure why, but I’ll just have to keep an eye on it the next few days and see if anything happens.
    Replacing the coolant for the engine and inverter, as well as replacing the water pump and thermostat was super straightforward and easy otherwise.
  13. Georgina Rudkus
    3,559
    2,599
    Taylors, SC
    Gotta love you, dogman.
  14. BiomedO1
    BiomedO1 Senior Member
    4,519
    2,378
    Left Coast
    Welcome Ryan;
    It looks like you did everything correctly. I would just check the coolant at every fill-up for a while - in case there's an air bubble in the system.
    That's one of the things I hate about these cars; no temperature gauge. Testing the fan functionality by turning on the AC is an old-school hack. This only tells you that the fans indeed work; but on a different circuit. Hopefully someone will chime-in with the trip-point for ICE fan activation.
    I've owned old Honda's; where either the electric fan or the trip-point sensor failed. Easy to troubleshoot them; because they all had temperature gauges in the instrument cluster. I do see your concern but unfortunately I don't have that answer. Sorry...
  15. ASRDogman
    8,042
    4,075
    ewwww.... NO YOU DON'T! EWWW
    Georgina Rudkus likes this.
  16. ChapmanF
    18,957
    Because the engineers are Japanese, it is easiest to remember the various programmed temperature points in Celsius, where the engineers picked easy round numbers. The engine coolant starts the fans at 95 ℃. (Or you can try to remember "203 ℉", but who has time for that?)
    I can usually get the coolant up to that temperature in not terribly long in maintenance mode, by holding the go pedal partway down.
    BiomedO1 likes this.
  17. BiomedO1
    4,519
    2,378
    Left Coast
    Thanks Chapman; Those sensors usually has a wide error margin; so if no fan activation by 205-215 degrees - I'd replace the sensor.
    On my old Honda; If it didn't trip slightly beyond the midway point - definitely before the 3/4 mark; I turn-on the AC to force the fans ON. I ran the car almost a year that way; when I was in high school and couldn't afford the sensor. Luckily; I wasn't in stop-n-go traffic too often - which was the only time the car was in danger of overheating. As long as your moving; heat isn't a problem on these modern engines.
  18. ChapmanF
    18,957
    When you're watching the temperature over OBD, then no matter what the error margin of the sensor, the sensor reading is the value that you are seeing. So you will hear the click of the fan relays right when the displayed number goes to 95 ℃. Like it's a number programmed into an ECU or something.
    Now, if you are reading temperature using some different thermometer you have inserted into the system, then yes, there is a separate question of what the error margin could be between your thermometer and the car's sensor.
