ICE in EV Mode ... Again
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PiPLosAngeles, Dec 9, 2012.
  1. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    As I've mentioned before, isn't it a Shame that we don't have access to a Toyota Engineer that KNOWS how and why the PIP works as it does?
    Yet, we keep plugging along guessing and assuming !!!
    52,807
    i tried neutral today, the ice did not fire. so, either it wasn't going to fire anyway, or somehow neutral prevented it. this is getting more and more confusing.
    52,807
    i've tried this to no avail. i would love to know battery temps before and after charging in several different ambient temps.
    52,807
    i have always been around 40 mph when the ice has fired.
    Tracksyde likes this.
  5. bisco
    52,807
    actually, the ice has never fired, once it runs for the first time. i have driven and recharged 3 times in one day, and the only time the ice fired was the first drive.
  6. lensovet
    2,615
    496
    Burlington, NJ
    but isn't it warmer later in the day as well?
  7. lensovet
    2,615
    496
    Burlington, NJ
    not confusing. remember, if our regen hypothesis is correct, this fits in nicely – N disengages the hybrid system completely and therefore disables regeneration.
  8. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    so......you're coasting downhill, in neutral, and you're applying the brakes.............
  9. lensovet
    2,615
    496
    Burlington, NJ
    exactly, and it will use friction brakes only. that's the point. so if you leave it in D and hit the brake pedal, it attempts to regen. however, because MG1 is spinning too fast and/or the battery is full and can't accept a charge and/or the battery is cold, no regeneration is possible, and MG1 ends up spinning up and running ICE. because this is the first time ICE is ever spun up, it ends up running its warmup cycle.
    but if you put it in N, no regen is ever attempted, only friction brakes are used, and ICE never spins up!
    cool?
  10. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    :cool:
  11. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    that gear shift lever is pretty tricky tho, I run into trying to put it in neutral when I'm in a car wash, accidently putting in reverse and having the tires buckle on the rollers in the car wash drive train.:cry:
  12. lensovet
    2,615
    496
    Burlington, NJ
    don't press the brake pedal when doing it and you won't do that
  13. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    force of habit:confused:
  14. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    Your experience jives with mine. You'll notice that the several times I've complained about the ICE firing for no apparent reason I was traveling in the 40 mph range. Isn't 42 mph or something the top speed of golf cart mode in the liftback? Perhaps coincidental, or perhaps there's an edge case that triggers the ICE to fire in the plug-in due to code designed for the liftback. That being said, it is also true that every time this has happened to me I've had nearly a full charge. I live on top of a hill, so when I start out in the morning I have to regenerate a little bit as I approach stop signs. Interestingly the ICE doesn't fire at this time. It's only a few minutes after I get to the flat part and reach ~40 mph that the ICE kicks on.
  15. bisco
    52,807
    no, the temps are pretty steady during the day. for december, there has been a lot of high 20's, low 30's overnight and high 30's, low 40's during the day. my car is in an attached garage, unheated which usually runs 5-15 degrees above outside air and rarely goes below freezing. also, many times, when i'm out in the evening, the temps are lower than they were all day. the funny thing for me is it fires more often in 40's weather than 30's and we haven't really seen 20's or lower yet.
  16. bisco
    52,807
    i didn't use the brakes. the hill is just steep enough that if i hit it around 25 mph, i'm going 40-45 at the bottom.
  17. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    so......you just shot through the traffic light/stop sign?:ROFLMAO:
  18. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    Those of you complaining the ICE firing while driving downhill, yes it is because the engine is trying to burn off the excess energy. I work on the edge of a very large hillside. After charging, once I hit the main street there is a steep degrade on the main road. I have to use neutral because once the vehicle goes beyond 85% soc and is regenerating energy on the downslope, the ice will flip on to grab the energy. I watch my SG2 like a hawk and once the vehicle is back to 84.7-85% soc, I put the car in neutral and break the rest of the way down the hill.
    If you don't have a SG2 (ScanGauge 2), I'm not sure how you would do this.
    lensovet likes this.
  19. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  20. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    In my case, its not the "normal" excess regen scenario that I'm encountering. I'm hypothesizing that as temperatures dropped (maybe from 60F to 50F or so), there is something else that is triggering the ICE to start.
    Now, it could be that the battery doesnt take regen as well as during moderate temps so the threshold is lower.. it could be at 45F, MG1 doesnt like being spun past 5000RPM.. maybe it does have something to do with going past 40 or 42MPH.. I think we're all flying blind and until we have more data, we just dont know.
    What I do know though is, for the past 9 months, I've had a really good handle on managing excess regen. However, in the past two weeks when it got relatively much colder here, things have been very different. Its not necessarily the fact that I'm burning gas or whatever, I just want to know why.
