ICE in EV Mode ... Again
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PiPLosAngeles, Dec 9, 2012.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Nope, not yet. Just posting as a data point so others can compare.
    priuskitty likes this.
    52,807
    not you, you flatlander!:p
  3. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    you said for noh expainable reason:p
    52,807
    do you have any fairly significant downhill in any direction leaving you house?
  5. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    like.......an abyss?:eek:
  6. bisco
    52,807
    actually, there are some here who have had the ice fire on flat ground if i'm not mistaken.
  7. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Yes, if I get caught at the first light after pulling out of the driveway. I wouldn't be going over 20 mph. ICE had never triggered.
    Return trip has longer steeper downhill. If I get caught at light, SOC is about 77-78%.
  8. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    ok, not so far for me tho. will update if it happens:D
  9. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    just finished my EV driving for the day, EV estimate right now: 1.3 miles, trip odo A, 8.6 miles, so EV range is down to 9.9 miles, with just Pandora and rear defroster, no headlights, no AC, no heated seats. Peak MPH about 35, average 20 MPH.:cool:
  10. retired4999
    2,652
    627
    Eau Claire, Wi.
    Nice Job! :)
  11. lensovet
    2,615
    496
    Burlington, NJ
    35! Damn, was someone holding a match to your butt? lol
  12. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I try to go the speed limit, even if it "pisses" people off:D
  13. bisco
    52,807
    left on my commute tonite, 44 in the garage, 27 outside. full charge 12.4 on the meter. goosed it to try to reduce the charge before i reached the ice trigger site. hit the trigger at 11.9 and the ice fired. rats!:mad: tomorrow, i'm going to try a partial charge and see what happens.
  14. lensovet
    2,615
    496
    Burlington, NJ
    Lol if I were you I'd just resign myself to using N and be done with it.
    But I guess if you want to torture yourself in the name of science…
  15. Chris11
    Chris11 Member
    220
    Washington
    K...to re-add to the confusion...today the ICE fired...same route...same temp...heater still on HI. The only thing I can think of is that I had to accelerate faster, nowhere near where ICE should have come on but still.
    The was someone behind me who wanted to break the standing start record and I caved so went from turtle to crawl and it fired. Not much crawl but apparently enough to piss off the computer.
    If we ever want to get a handle on this car we have to kidnap a Toyota computer engineer, put him in a room with Priuskitty until just before the computer engineer's brain explodes (which may not be too long) and demand he tell us the secrets.
    rogerv and Tracksyde like this.
  16. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    aw....that's just plain mean:cry:
  17. bisco
    52,807
    the mystery continues...:confused:
  18. ny_rob
    ny_rob Senior Member
    1,968
    814
    L.I.- NY
    It's a no-win situation in cold temps, if you step on it trying to burn off some battery- once you reach a sufficient speed that the PIP calculates a hard break re-gen would overcharge the battery (at it's current low temperature) the ICE fires up anyway just in case. If we could all drive 20mph for the first few miles after a recharge- then we'd avoid the ICE startup- but I have to go faster than that on my own street!
    We just have to live with the fact that the current software and hardware aren't optimized for near/below freezing temps. Battery protection trumps fuel economy. Oh well... even when the ICE fires up early due to the battery protection protocol- I can live with 74-80mpg on my trip to work... can't wait to see what mpg I'll get in the spring :)
    Tracksyde likes this.
  19. bisco
    52,807
    i just did my commute with a partial charge, pulled the plug at 11.7 instead of 12.4 which is a full charge lately. temp was 40 in the garage and 22 outside. hit my ice firing dip at 11.3 and it stayed off!:p i'll keep doing this until i'm comfortable that the solution is leaving a little room in the battery.
    usbseawolf2000 likes this.
  20. retired4999
    2,652
    627
    Eau Claire, Wi.
    :cool:
