ICE in EV Mode ... Again
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PiPLosAngeles, Dec 9, 2012.
  1. bisco
    52,807
    tried it again tonight and it worked again. 17 degrees out, no ice. only problem now is, i have to stay at work longer to get enough charge to make it home.:rolleyes:
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Great to hear. Stay extra 5-10 mins longer?
    You can try this method.... Charge it full. Before you leave, turn on both heated seats to HIGH. Once the seats get hot (about a min), leave the house.
    Each heated seat at High pulls about 0.3 extra amp, so the idea is, they would lower SOC enough in a min. PiP electronics (inverters, etc...) idling pulls 1.2 or 1.3 amp. Maybe turn up the sound too but I have only seen maybe 0.1 amp draw from the sound system.
    52,807
    :) yes, i pulled into my garage with .1 left and was sure the ice was going to come on! and that was nursing it all the way home. i'm definately using the drivers seat. i can drive in the opposite direction for a tenth and come back, but in the end, i'm accomplishing the same thing. or i could use len's method and just put it in neutral. kinda wish i had a decent electric heater now to point at the windshield!
  4. Chris11
    Chris11 Member
    220
    Washington
    I was reading the manual (halelujah) and it mentions that if the battery temp is too high or too low the ICE will start. That's one parameter I haven't been watching but will from now on. At least the cold part at this time of year. :)
  5. bisco
    52,807
    mine is in a 40-45 degree garage and i typically charge just befor leaving, so battery temp is probably higher than someone who charges outside and finishes earlier than they leave. however, priuskitty charges outside and her engine never comes on, so that may kill that theory.
  6. El Dobro
    El Dobro A Member
    7,102
    3,282
    Her?
  7. bisco
    52,807
  8. El Dobro
    El Dobro A Member
    7,102
    3,282
    More like him. :D
    lensovet likes this.
  9. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    For me it's to understand why the engine starts so that we can determine if it's something that the driver can control if they wish to keep the engine off. Also, I do not believe there is anything mysterious about the Prius' logic. It was programmed by people and that programming can be reverse engineered through careful testing. You can't use a tool to it's fullest potential if you don't even really know how the tool is going to behave.
    That being said, I'm 99.9% certain that mine is a case of excess regen. Using neutral downhill has eliminated the mysterious engine firing. I just can't figure out why it waits until I'm done going downhill and driving along at 40 mph before coming on.
    EDIT - Apparently the way the logic works is that the ICE fires once the PiP's inertia is sufficient that braking would regenerate enough to overcharge the batteries. That explains why we're all seeing the ~40 mph trigger.
    Tracksyde likes this.
  10. Chris11
    Chris11 Member
    220
    Washington
    I knew Priuskitty before the operation. Not much difference ... same size breasts. :ROFLMAO:
    rogerv and lensovet like this.
  11. bisco
    52,807
    wow, p/k must be taking the night off!
  12. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    watching CSI NY and Blue Bloods lol. Maybe driving 15 MPH initially warms up the battery due to the chemical reaction of the battery discharging, because when I went to Sam's Club the other day I drove down the side streets with a speed limit of 25 MPH (going 15 to 20 MPH) till I had to enter 13 mile road at 35 MPH. and, yes, my man boobz are the same size. lol:ROFLMAO: :LOL: :D :cool:
  13. lensovet
    2,615
    496
    Burlington, NJ
    pk, how much longer before your signature takes up my entire screen?
  14. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    oh.....wait......there's more.......let me see......where did I put that info?:p
  15. Why, start charge earlier.
  16. Coming home yesterday after exhausting EV, my last 4 bars were 100 mpg, 1 min. Bars. ( Pulsing and gliding ) 35 mph speed limit, gentle rolling hills.
  17. bisco
    52,807
  18. Yes, any idiot can get 100 mpg bars in EV , the real trick is to do it in HV.
  19. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    here's proof I'm in EV during January:D
  20. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    in case there any liability issues:ROFLMAO: :LOL: :p
