ICE in EV Mode ... Again
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PiPLosAngeles, Dec 9, 2012.
  1. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    is this a test? Isn't the answer in the wan n only Prius Plug In FAQ?:giggle:
  2. 3PriusMike
    3,101
    2,421
    Silicon Valley
    My question was "how does warming up the engine get heat to the battery" and I think the answer is it doesn't. Warming up the engine gives you the option of warming up the cabin. If the cabin is warm then the battery can get heat via the fans.
    Mike
  3. lensovet
    2,615
    496
    Burlington, NJ
    There's two points:
    ●The temperature of the hybrid system is low: The vehicle has been left in temperatures lower than about 32°F (0°C) for a long period of time etc.
    ●The outside temperature is low (less than 14°F [-10°C])
    Both of these apply to John and ny_rob. Neither of them apply to you, I thought, because we discovered the excess regen issue. But if putting it into neutral every time doesn't do it for you, then perhaps you're hitting the first case, where car has been out below 32 for too long.
    Btw, re: how does engine running heat the batteries, it doesn't. But it's the same way as in hot climates, running the fans to exchange heat with the cabin technically doesn't do much either. I think the assumption made by the engineers is that at such low temperatures, you'll stop torturing yourself and just turn on the damn heater :p
    rogerv and priuskitty like this.
    52,876
    they don't know us very well, do they?;) yes, that's not my problem. i think it's the excess regen and possibly a mph kicker. it hasn't been cold enough yet to test anything and when it has been below 32, the ice hasn't come on, although, i store it in warmer temp. i'm just curious as to what john is experiencing.
  5. El Dobro
    El Dobro A Member
    7,106
    3,282
    My owner's manual says "ICE activity may create long thread on Prius Chat".
  6. retired4999
    2,652
    627
    Eau Claire, Wi.
    :ROFLMAO:
  7. bisco
    52,876
  8. OK,I think I have it. Charged to 11,started out in HV, turned on heat and defrost as needed, car automatically either blends both or I revert to EV when I see that the instant mpg is not 100. Did not look at the to portion, but it was better than the from, still had 3 miles. Coming back, I used the same procedure, charged first, started in HV. got home with about .1 mil of EV. Left. Trip mileage was 105 mpg for 15 miles. Terrain: rolling hills, Traffic: was half freeway and half suburbia. The overall average also increased by 1 mpg. Observed Speed Limits.Temp. In low 40 s. So don't get paranoid about using heat, defrost or EV. One can still get great mileage in the Winter. That is ( California Winters ).
  9. bisco
    52,876
    andy, are you saying the ice came on in ev mode, or did not?
    Andyprius # 1 likes this.
  10. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    Mr. Toyota Engineer? Where are you ??? We need your Input !!!
  11. I am saying that I did not care what mode I was in, as long as the instant mpg shows 100 mpg. Initially after the engine warms up.You can technically be in HV, but also Eco and EV and engine is running, but still getting 100 + mpg.after a short period the car goes totally in green "EV". Even if I'm running in EV and the terrain is right, I will go into HV to save EV for when I need it. Very often at this stage the engine does not come on anyway.when do you need EV? When going uphill, so the instant mpg indicator shows 100+. Comprende ?
  12. bisco
    52,876
    gotcha, this is not about ice in ev mode, it's about using pip in the most efficient way as john is always saying.;)
    usbseawolf2000 likes this.
  13. Correct, forget the ICE, the defroster, the fans, use all as needed. Just keep your left eye on the I MPG Indictor......................(Instant).
  14. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Yup, keep it simple. We just want to outsmart PiP and make it more fun.
  15. bisco
    52,876
    exactly. where's the joy in just driving it?:D i'd rather fmao.:ROFLMAO:
  16. . Freze my nice person off, or..fart my nice person off. Or f ck my nice person off. WHICH ONE?
    There are many interpretations, in Wickipedia.
  17. 3PriusMike
    3,101
    2,421
    Silicon Valley
    I believe (at least for the G1 Prius) that if the battery got too hot the A/C is forced on...not true anymore?
    Mike
  18. That is interesting, John 1701 I believe had a Gen 1. In fact his. Site may include the Gen1.
  19. bisco
    52,876
  20. 3PriusMike
    3,101
    2,421
    Silicon Valley
    I had a Gen1 and I had the A/C come on once. But I can't recall if the G2+ also do this.
    Mike
