ICE in EV Mode ... Again
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PiPLosAngeles, Dec 9, 2012.
  1. bisco
    52,876
    i screwed up and had to leave a bit early. charge wasn't finished and ev range said 12.5 instead of 12.9. ice never came on but i don't think i accomplished any testing.
  2. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    Sorry for the delay. Christmas season is hectic around here. How do you determine the temperature the HVAC is set to when it's off? Mine just shows the outside temp and nothing else on the entire display.
    52,876
    if you turn the fan on, the hvac temp shows on the display.
  4. PiPLosAngeles
    1,551
    724
    I always drive with the fan off. Usually even with the radio off. I was just assuming people could see a temp even when it was off, but now I see they mean when the A/C compressor was off and not the fan.
  5. bisco
    52,876
    if the temp is above 'low', it doesn't matter if the fan is off. the computer still thinks you want heat and starts the engine.
    lensovet likes this.
  6. lensovet
    2,615
    496
    Burlington, NJ
    stupid computer
  7. El Dobro
    El Dobro A Member
    7,106
    3,282
    It was shopping time again, like last week. About 7 mile round trip, the temp outside was 45, HVAC at 68 with fan off. The ICE did not come on at all. I also noticed that the charge was at 11.1 when I started and 7 when I got back.
  8. bisco
    52,876
    68 and no ice? that's amazing. mine fires right up if the coolant is cold.
  9. ny_rob
    ny_rob Senior Member
    1,968
    814
    L.I.- NY
    My car sat outside overnight as usual, but it was pretty mild last night (in the high 40's to 50deg) this morning when I was ready to use the car it was already 52deg outside. Happily the ICE did not fire up this morning on my street as it's done on the colder mornings lately. I was able to run in full EV mode till I got to the Expressway and hit 65mph. So in comparison to yesterday's poor 74mpg due to ICE firing up early, headwind with rain- today I got 92mpg at the end of my 28mi commute.:)
  10. El Dobro
    El Dobro A Member
    7,106
    3,282
    That was also the first time I used the car that day.
  11. bisco
    52,876
    45 degrees today, battery fully charged, ice came on in the same place. i swear within 10' of the same place every time. creepy.:eek:
  12. PiPLosAngeles
    1,551
    724
    How do you tell what the temperature is set to when the fan is off? Turning the fan on to get a glimpse of the temperature is likely to fire the ICE if it hadn't already, so that's not a good way to go about it.
  13. lensovet
    2,615
    496
    Burlington, NJ
    put the car into ON mode (two pushes on the power button without depressing the brake pedal) before starting it. no other way really.
    EXCEPT…Torque users, is there a way to see this value in the app?
    Edit: Personally, I just always leave it at that temperature. Thankfully, haven't had a need to run the climate control at a higher temp yet. But basically that is your best bet, just remember to always set it to LO before turning the car off.
  14. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I've tried to see battery voltage while looking at my ScanGaugeII when in ACC mode. No luck doing that tho:cry:
  15. lensovet
    2,615
    496
    Burlington, NJ
    i meant while the car is running. i.e. see the temperature setting without turning on the fan.
  16. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    No way to see the climate control temp in Torque that I know of. It doesnt seem likely to be a piece of data available from the OBD2 port.. but I'm no expert.
    I just leave mine in LO all the time as you suggest.. works for me. Not as convenient, but I try not to use climate control at all anyway.. big change for me since my last car was pretty much always set to 70 with AC on...
    delrey likes this.
  17. lensovet
    2,615
    496
    Burlington, NJ
    easier for you to do in the southland :unsure:
    delrey likes this.
  18. bisco
    52,876
    if the fan is off and the ice isn't firing, i wouldn't worry about it. i was just saying, if anyone is wondering why the ice is firing, the problem might be that temp is above 'low'. many think having the fan off will keep the ice off. doesn't work that way in my car, although el dobro has been able to drive with temp at 68, no fan and no ice. i definitely believe each car is a little different.
  19. Zimmy 1
    Zimmy 1 Junior Member
    61
    Smithtown NY
    I would think that a nice detailed letter to Customer Service Toyota would at the very least let them know what is happening. Maybe it is a software update, or a very correctable condition. Two letters, one to the Dealer and one to Toyota National.
  20. El Dobro
    El Dobro A Member
    7,106
    3,282
    When you set the temp, it holds the setting even after you shut down and restart the car.
