ICE is Running, SoC is high, Car is Parked - ??!?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PriusNeckBeard, Nov 15, 2016.
  1. PriusNeckBeard
    PriusNeckBeard Active Member
    376
    211
    Cincinnati
    Is this normal?
    I'm new to winter in this car.
    This past Fall, parked, ICE seemed normal. When I was parked in Ready mode, when SoC dropped to about two bars, the engine would kick on for a short amount of time. SoC might even raise a bar, and engine would cut off. Fine.
    Last night, I was parked, Ready mode, SoC at the next to highest level. (I've never had all bars lit).
    Heat on.
    After a few minutes, SoC would drop a bar, engine would turn on! Same process as in the Fall -- once it raises a pip, engine cuts back off. Wait a few minutes, the process repeats.
    Is this normal?
    Is it because the heat was on?
    I was expecting the SoC to drop to two pips before the ICE cut on.
    Thanks,
    - P
  2. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    It was probably due to your heater setting. The only way to generate heat for the cabin is to run the ICE to warm the coolant.
  3. Mendel Leisk
    42,377
    Repeat the situation, and lower the cabin temp, see if engine will then shut down. I've found, especially when the car's halfway through warm up, I can turn engine off/on via cabin temp setting.
    jerrymildred likes this.
  4. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    For that experiment, you have to lower the cabin temp all the way down to its lowest setting, and it just a few degrees.
  5. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    With cooler temps your ICE will run more. First to warm up the ICE pollution control systems and second to warm the cabin. The ICE will shut down if demands permit, but it will run more than when the temps are a bit milder.
  6. Mendel Leisk
    42,377
    I'll often stop at a red light, about 1/2 km from home. Coolant temp typically around 50C. In that scenario, somewhere around 21C cabin temp setting is the threshold: higher, engine goes on, lower, it goes off. 21C's something like 68F?
    And yeah, ambient temps are a factor too.
  7. Rebound
    3,996
    2,645
    Portland, OR
    No... if you have the heater set to any temperature, the engine will start in order to heat the coolant. And it will restart, and restart.... Remember, my Prius is a plug-in, so the engine in my car can stay off even if I drive ten miles. But if the cabin heater is set to any temperature above the very lowest setting, the engine will start and restart to keep the coolant warm.
    Coast Cruiser likes this.
  8. Mendel Leisk
    42,377
    Ok, apples/oranges. But, OP does not have a plug-in.
  9. GT4Prius
    GT4Prius Active Member
    530
    412
    Cumbria, UK
    Excel
    Just switch the AC off. Works for me. Engine goes off straight away.
  10. PriusNeckBeard
    376
    211
    Cincinnati
    So even with high SoC, engine will run to heat things. Huh. Never knew that.
    Just repeating that to make sure we're on the same page..
  11. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    Very foggy this morning and 55 degrees. I actually got a bit nippy walking in my shorts and T-shirt. :LOL: I had the temperature set at 70, and I did notice that the engine came on more frequently when I was parked. But that's fine, now I know it works and it keeps me nice and toasty.
  12. Rebound
    3,996
    2,645
    Portland, OR
    The AC is electric so it won't necessarily start the ICE, but if the engine is cold and the heater is above MIN, the ICE will need to start up so that the engine coolant can be warmed.
  13. Mendel Leisk
    42,377
    On the plugin yes, but neither GT4 nor OP have plugin.
  14. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,145
    Franklin TN
    I slept in my car once on a cold winter night. I set the air to 65 and the fan to 2, the engine came on about every 8 or 9 mins and ran for like 45 seconds at a time. Woke up seven hour later to 6 bars SOC. Used about a gallon of gas all night. Gosh I love my car ❤️
    m.wynn likes this.
  15. Rebound
    3,996
    2,645
    Portland, OR
    I think that what I'm saying applies to the standard Prius. The Plug-in just runs on electricity longer.
    If I cold start and the heater is above MIN: Engine starts immediately, and it won't shut down until it's fully warmed up. :-[
  16. PriusNeckBeard
    376
    211
    Cincinnati
    So, how does engine behave if heater is on minimum? Jc.
  17. GT4Prius
    530
    412
    Cumbria, UK
    Excel
    The control I use is the Ac Auto button on the steering wheel. The Auto Climate aspect of the car blurs the distinction between the heating and the cooling aspect of AC. I agree that it is the heating aspect of AC that requires the ICE to run in order to heat the coolant so as to heat the cabin. Heater setting is in relation to cabin temp so if colder in cabin than min car setting I guess heat requirement Will turn on ICE, assuming engine is cold or insufficient heat in coolant.
    May differ slightly on US models due to their electric heating element in heater.
    Only sure way IMHO and in my experience to avoid ICE coming on to provide cabin heat is to turn off heat (aka AC), which is easily done on my Gen2 using aforementioned button.
    (Ps I also agree that the cooling aspect of AC on my Gen2 is electric and can run without the ICE depending on state of charge.)
    #17 GT4Prius, Nov 16, 2016
  18. Coast Cruiser
    2,267
    2,571
    I don't see any button in my Gen4 that says "Heat." :ROFLMAO: So I just make sure the "AC" button is off, and turn up the Temp.
    Gotta keep things simple for us old dudes.
  19. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Just remember: In a hybrid, all energy comes from gasoline. The battery is just a storage unit not a source of energy. The less energy you use (or request) the less gasoline you'll use.
  20. Rebound
    3,996
    2,645
    Portland, OR
    If the heater is set to MIN, it's off. So the engine coolant does not need to be heated. Therefore, the engine will not start in order to warm or reheat the engine coolant.
    This is easier to observe with a Plug-in Prius but it will happen with any Prius: When you put the Prius in Ready and heater temp is MIN, the engine will not start. But if you then raise the heater temp and start the fan, the engine will immediately start.
    PriusNeckBeard likes this.
