ICE not starting automatically at start-up
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Alex77, May 24, 2016.
Tags:
  1. Alex77
    Alex77 New Member
    Dallas
    I replaced the 12V battery yesterday with a new one, and the car (2010 Prius Model III w Navigation), will turn on and off, but the ICE is not turning on automatically upon start-up, as it usually does. I can get the ICE to start by stepping on the gas pedal while in park, although it seems to die within a few seconds if I remove my foot.
    The original issue was that the car died completely yesterday after parking. The same issue had occurred 3 years ago, and a new battery resolved it, hence my inclination that replacing the battery will work again. Everything else seems to be functioning normally, although I am not a technician.
    I have searched around, and there are many comments on trying to reset the computer, clearing error codes, etc, but I am unsure what steps to take. Usually, the gas engine (ICE) will run for 20-30 seconds after turning the car on, even while in park.
    The READY light DOES come on when turning the car on, and the ICE appears to turning on once driving above a certain speed. Also, there is plenty of gas. Does anyone have any suggestions or thoughts?
    52,672
    welcome! it may be fine.
    how many miles on here?
    does the battery icon act normally?
    were there any dash lights lit when you had the problem?
    how are your mpg's?
    you may need to have the codes read at toyota.
  3. Mendel Leisk
    42,165
    Strange. How many miles on it? No warning lights?
    (Yeah, I know, an echo)
    52,672
    helllloooooo...........hellllooooooooo..........hellloooooooooooo........
    Raytheeagle and Mendel Leisk like this.
  5. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    As pointed out here recently, the ICE can start anywhere from 2 - 3 seconds to 15 seconds or so after hitting the start button. Have you waited at least that long to see it it does start?
  6. bisco
    52,672
    perhaps when the 12v is bad, it starts sooner to try and charge.
  7. Alex77
    Alex77 New Member
    Dallas
    70k miles. The Dash went completely dark when the issue first occurred. MPG's are ~ 45 normally. The battery icon seems to be acting normal, is there anything to specifically look for?
    In response to DonDNH- yes, I have waited a good 60 seconds to see if the ICE will start.
  8. Mendel Leisk
    42,165
  9. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    If the car is heated up to a certain point in the warm-up process, not sure what happens in that case.
  10. qdllc
    qdllc Senior Member
    1,377
    400
    Not an expert, but to my recollection, the ICE stays off until there's a need.
  11. bisco
    52,672
    the battery icon typically stays near the middle, 5-6 blue bars, but of course, can go down to two purple or up to 8 green, depending on conditions. eventually comes back to the middle as you drive.
  12. Mendel Leisk
    42,165
    Third gen battery status doesn't have colours tho. Well, pale green. :rolleyes:
  13. tv4fish
    tv4fish Member
    202
    46
    Correctomundo -- And our battery monitor is usually only showing 2-3 blank "bars" at the top. It DOES get daily use, also.
  14. bisco
    52,672
    interesting. you'd think i'd know that after 4 years, but i don't drive in hv enough apparently.
    Raytheeagle likes this.
  15. Former Member 68813
    3,524
    983
    US
    my suggestion is this is normal.
  16. Alex77
    Alex77 New Member
    Dallas
    Just wanted to close the loop on this thread, for anyone who encounters this in the future.
    For some unknown the reason, the ICE began its normal behavior 1-2 days after the 12V battery replacement. When starting the car (while parked), the ICE will turn on typically around 5-15 seconds after turning the car on. I wonder if the ICE turns on based on the overall temperature (suggested earlier) or certain car settings (e.g. if A/C is turned on). But, alas, the car is back to normal. Now, I hope I will get a good life out of this 12V battery. Thanks for everyone who chimed in.
    bisco and Mendel Leisk like this.
  17. bisco
    52,672
    congrats!(y)
