ICE Oil Pump
Discussion in 'Gen 3 Prius Technical Discussion' started by Jonny Zero, Sep 13, 2012.
  1. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Does the Prius ICE have a pre-oiler? With all the starts and stops I would think one would be prudent to have, to prevent a dry start, or two, or many.
  2. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    No. Not necessary as the engine is spun up to 1200 RPM before any load is put on it or fuel is injected into it.
