ICE On in EV Mode!
Discussion in 'Prime Main Forum (2017-2022)' started by mr88cet, Jun 22, 2017.
  1. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    I just noticed a short period of time with the engine on in EV mode!
    In particular, I dropped my wife off at a friend's place. I didn't tally up the distance exactly, but I presumed it to be bigger than a 30-mile round trip, so I decided to burn a little gas. More specifically, there's a stretch on an 80MPH troll (haha) road, so I took all but that part in EV mode, and fired up the engine for the 80MPH part only, both coming and going.
    Interestingly though, a mile or so before I exited the 80MPH toll road on the way back, I switched back to EV mode, and the drive monitor showed the EV indicator on and the ICE still running! I tried to take a picture of it, but I had some traffic to deal with, so I didn't succeed in doing so.
    Apparently, that close to the 84MPH EV-speed limit, it doesn't shut off the ICE immediately when you switch HV->EV.
    iPad ? Pro
    bwilson4web and HPrimeAdvanced like this.
    52,803
    it probably has to go through pollution protocol before shutting down.
    Prius from Dad and Lee Jay like this.
  3. mr88cet
    2,313
    1,335
    Austin, TX
    What sort of protocol would that likely entail?
    iPhone ? Pro
    52,803
    no idea, maybe the sensors wait until the right temps and hydrocarbons. just a thought. how long did it run for after you hit the ev button?
    my pip often runs the engine after i come off the highway and hit ev, but prime may be different.
  5. mr88cet
    2,313
    1,335
    Austin, TX
    Probably a couple minutes or so. It seemed to turn off as I turned off -- as to say, took the exit. I'm guessing it's more related to slowing down than to some particular amount of time.
    iPhone ? Pro
  6. bisco
    52,803
    interesting. also the drive monitor isn't real time. it's off a bit. you need a scan gauge or something for more accuracy.
  7. DavidA
    2,349
    1,825
    Chicago western burbs
    The normal 200 miles auto-ICE cycle perhaps?
  8. Mark McIntyre
    Mark McIntyre Member
    36
    51
    Boulder CO
    In my experience it takes several minutes/miles before the ICE kicks off when I have switched it to HV mode back to EV mode. No reason as to why but it does consistently take a while
    Son of Gloin and bwilson4web like this.
  9. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    doesn't apply to the Prime, there are posters that go 800- 900 miles all EV and ICE did not come on.
  10. Tideland Prius
    16,674
    We still have to figure out that interval! haha
  11. priuscatprimeguy
    2,730
    2,640
    well, I'm turning 65 next Tuesday, can we get it done by then? Or anytime in my lifetime?:p
  12. mr88cet
    2,313
    1,335
    Austin, TX
    I have not myself noticed that, other than this particular time, and a couple times when was still in warm-up.
    On the other hand, the engine is pretty quiet most of the time, so there's a chance it may have stayed on longer than I realized. Also, I've so seldom run it on gas that ... well, let's say that would be my favorite reason to not have, perhaps, noticed it!
    iPhone ? Pro
    priuscatprimeguy likes this.
  13. mr88cet
    2,313
    1,335
    Austin, TX
    Still, the fact that, in hybrid mode, the engine turns on and off on a second-by-second basis, conceptually, it would seem like it could shut off the engine in a matter of seconds, assuming it's not being held on for other reasons, such as warming up.
    iPhone ? Pro
  14. bisco
    52,803
    i suspect that the prime engine is so quiet, the people who think it hasn't come on in 800-900 miles never heard it.
    Trollbait likes this.
  15. bwilson4web
    16,516
    Road trip:
  16. 34Hupp
    34Hupp 1934 Hupmobile - Americas 1st Aerodynamic
    62
    100
    Rochester, NY
    I think the PIP was around of 150 miles of continuous EV operation and it would kick on the ICE for a complete warming cycle. I only had that occur a few times in the 46,979 miles with my PIP. The Prime is much greater than that; this morning I crossed 2,000 miles without the ICE coming on. Last time the ICE came on was early April. The car has 4,047 total miles, and 2,027 miles since the last time ICE turned on and completed a warming cycle (for unknown reason). I still have a "full dealer tank" of gas I need to start using! (my "miles to fill-up" still shows 484, so "no", the gas engine has not been turning on unnoticed!)
  17. bisco
    52,803
    but prime now separates ev miles from hv miles, unlike pip. dte will remain the same unless you hit hv mode,
  18. Pdog808
    Pdog808 Active Member
    434
    290
    Los Angeles
    2018 Prius Prime
    From what I have observed, if the ICE has run through it's entire warm up period, when you switch from HV to EV it happens instantaneously. If the ICE is still going through it's warmup when you swap back to EV, it will keep running for awhile.
    I tend to judge whether the car has fully transitioned to EV by observing the large green EV icon you see on your instrument panel. When the car is still going through the ICE warm up, I've noticed that swapping back to EV does not immediately "fill in" the green EV icon. After an unknown amount of time, the green icon will "fill in" and be fully illuminated.
    If the ICE is fully warmed up, swapping back to EV mode results in the icon illuminating immediately. (Although there seems to be a few caveats to this - not sure if it is speed related or something else)
  19. 34Hupp
    62
    100
    Rochester, NY
    .... or consume gas.... That was my point...... someone commented that the engine is so quiet (no it's not) that people are not hearing it turn on and are not really getting long continuous EV runs without the ICE turning on. If my "miles to fill-up" display shows the same number since early April, then "no fuel has been used", and thus the ICE has not turned on (in the last 2,027 miles)
  20. priuscatprimeguy
    2,730
    2,640
    Plus, your ECO dashboard resets to zero at the beginning of each month, surly you would see a deviation from 999.9 miles EV if ICE somehow kicked in without us knowing it.:eek:
    34Hupp and Prius from Dad like this.
