ICE On/Off Transition Smoothness
Discussion in 'Gen 3 Prius Main Forum' started by Jonny Zero, Jul 20, 2012.
  1. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    So far I think the ICE on/off transition is pretty smooth. The most noticeable one is the initial cold ICE fire up. Once the engine is warm, I have to watch the EV icon to see when the ICE is coming on/off.
    Question to members with higher miles Gen IIIs, does the transition get rougher with miles as the engine / motor mounts get older and stiffer?
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I think so... it use to be I could hardly notice it, now not so much.
  3. bwilson4web
    16,537
    We have both a 2003 Prius with 100,000 miles we drove and a ZVW30, 2010 Prius with 30,000 miles. I've never felt a transition with these exceptions:
    • NHW11 at over 42 mph - shift to "N" and wait for speed to get under 42 mph, shift briefly into "D" and back, the engine will stop and a very faint shutter can be felt. Normally the Prius stops the engine with positive control so there is no shutter.
    • One a year, in the fall, the engine will go through about 10-15 seconds of rough running. It happens one in the fall and never again until the next fall.
    The Prius control laws actually use MG1 to help mechanically bring the engine to a soft-stop at what we think is a fixed position. But it is so smooth, I have to use instrumentation to tell when it happens.
  4. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    I have 64K miles and can tell no difference from when it was new. I am more familiar with what the transition feels like, so I am aware of the transition ... but it is remarkably smooth, and when someone rides with me and I demonstrate the system, they generally are unable to feel the change.
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I have just under 50k miles on mine and I still have to watch RPM on my ScanGauge to tell for sure the ICE is off. Like Felt above, when I have people ride for the first time they are amazed at how smooth the transition is and ask how they do this so smoothly.
  6. Matt M.
    Matt M. Member
    117
    San Francisco Bay Area
    OK, here's a related question. On my 2012 Four, especially when the car is not moving, I notice that the sound and feel of the ICE change a little bit for about 1 second before the ICE shuts off. Does the car make some kind of adjustment to the timing or mixture or something in preparation to shut off the engine - does anyone know? Just curious.
  7. bisco
    52,863
    yes, it sets up for the next 'smooth' start. timing has to be in the right position. does this at every shut down. amazing, isn't it?
  8. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Valve timing or spark? I would think spark can be changed on the fly, since it is electronic.
  9. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    Not insofar as I can tell. With 68000 miles, I still appreciate how quiet and smooth the transition is. In my opinion, I am more aware of a transition only because I am more familiar with the car. Passengers have no idea if the ICE is running or not.
  10. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Mine must be as smooth as ever at 77K miles because I don't notice it at all. I usually have to look at the tach to tell if it is running or not.
  11. Tande
    Tande Active Member
    556
    339
    Mich.
    Yours has a tach.? .......Which trim level? .....
  12. tumbleweed
    4,067
    692
    Eastern Oregon
    Not original equipment, I just use the one in my ScanGauge. Along with the tach I usually monitor coolant temps and Amps to/from the traction battery, or sometimes 12V battery voltage.
  13. Tande
    Tande Active Member
    556
    339
    Mich.
    Oh, OK, excellent! (y)
  14. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    To anyone with a Scan Gauge:
    I do not know that I actually NEED a scan gauge, but I recognize the information that they provide would be very useful. One thing that has held me back from purchasing the device is ..... where have you mounted the device? How large is it? How about a photo of your installation.
  15. tumbleweed
    4,067
    692
    Eastern Oregon
    I like mine mounted on the steering column using velcro, it's easy to mount and easy to see. But this thread may give you some better ideas, check photos in post #10. Spot for Scangauge? | PriusChat
    Felt and spiderman like this.
  16. markabele
    5,084
    1,782
    Nebraska
    A great, and cheaper, alternative if you have an android is to just get a cheap bluetooth obd with the torque app.
  17. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Which BT ODBII connector did you get?
  18. markabele
    5,084
    1,782
    Nebraska
    One of the cheap ones from amazon, can't remember exactly. They should all do the same thing. Just get one of the highest rated ones for 20-25 bucks.
    spiderman likes this.
  19. Former Member 68813
    3,524
    983
    US
    i know this is old, buy i'm going to add on instead of starting a new one. I noticed that since my 2010 has over 80,000 miles, the transition is a whole lot more noticeable, especially if cold. sometimes the whole car shakes (slightly that is) when in park or slowly creeping and the ICE fires up.
    Tbkilb01 likes this.
