Ice/snow buildup on fender/wheelwell liners causing damage
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by alw, Oct 21, 2017.
  1. CR94
    CR94 Senior Member
    2,695
    1,174
    Northwestern S.C.
    Why not try silicone spray before more extreme measures?
    #21 CR94, Dec 22, 2017
  2. alw
    alw Junior Member
    Boston MA
    A post-winter report:
    After (hopefully) the last of a long series of Boston snowstorms, my wife reports that she has never had any further problems with fenderbergs sticking to the Prius. So Fluid Film seems to do the job!
    We will continue to monitor for any signs of degradation of rubber components (the manufacturer warns about this possibility), or summer buildup of dirt. Assuming we see no problems, we probably will reapply a spray coating to the wheelwell liners in late autumn.
  3. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    Great report. I had Fluid Film applied on under body of my Gen 3 Prius for rust prevention, but I don't think it was specifically applied to the wheel well liners. I never had too much problem with freezing ice and snow on those part, for our temp are usually lower than Boston and road does not accumulate slush. It stay either as compacted snow or completely frozen ice, so they don't stick. I was thinking of applying Fluid Film on my new Prime before the winter season, but the garage I took to told me under body plastic shields covers everything, there is nothing to spray on.
    Bay Stater likes this.
  4. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Where was this product obtained? Thanks.
  5. Salamander_King
    11,019
    8,954
    New England
    There is something about inserting Amazon URL into here that gets changed to unknown media that prevent displaying a link. I just captured the page from Amazon. Just search "Fluid Film" in Amazon, you will find this page.
    You can buy at most major auto supply stores, hardware stores, or from most of on-line retailer like Amazon or Walmart. They sell in different forms like 5 or 1 gallon can for large application, but for DIY of small areas like the one OP is using, spray can is most convenient.
    #25 Salamander_King, Apr 15, 2018
  6. farmecologist
    farmecologist Senior Member
    1,958
    1,799
    Southern MN
    I've heard of some folks using FluidFilm in the wheelweel liners :
    oops..someone beat me to it ( see above ).
    I'm going to try this on the rear of my Prius v (wagon) at some point. Turns out the v (wagon) doesn't have rear undercover panels ( which is disappointing ) and there is some rust starting back there.
    Unless someone has a better alternative...of course. Are there any recommended 'rust inhibitors' that are more permanent than FluidFilm? I was considering this for metal areas :
    #26 farmecologist, Apr 16, 2018
  7. Carl Mims
    Carl Mims Junior Member
    Bozeman, MT
    2015 Prius v wagon
    How did this work out? Did you find the proper thing to use. I have extreme problems in MT with buildup and can not chip it off. I have to take to a heated carwash and blast off with pressure cleaner.
  8. alw
    alw Junior Member
    Boston MA
    Have been spraying Fluid Film on the wheelwell liners late each fall, and my wife has never had another problem with fenderbergs. By the way, Fluid Film is the only lubricant officially recommended by Medeco, a manufacturer of precision high-security lock mechanisms.
    Medeco Cylinder Lubrication
  9. farmecologist
    1,958
    1,799
    Southern MN
    FluidFilm ended up working great on nearly everything. I think of it more as a metal protectant...but it did work on the wheel well liners.
    alw likes this.
  10. alw
    alw Junior Member
    Boston MA
    A minor correction: Fluid Film's active ingredient is actually lanolin, the natural waterproofing that preserves sheep's wool. It works amazingly well for preventing fenderberg formation.
    farmecologist likes this.
  11. Mendel Leisk
    41,489
    South Main Auto guy (YouTube) uses fluid film, and has a baaing sheep sound bite every time he brings it out. (y)
    alw likes this.
  12. alw
    alw Junior Member
    Boston MA
    A continuing update:
    We have been spraying Fluid Film on the inside wheelwell liners of our 2010 Prius every late fall season since 2017, and have never again had to deal with fenderbergs since then. The stuff works really well to prevent snow and ice buildup, and is also promoted as a corrosion inhibitor.
    An interesting development is that Medeco Security Locks now exclusively recommends using lanolin-based Fluid Film spray to lubricate their precision high-security locks. This supersedes their previous recommendation to use a Medeco-branded PTFE-based lock lube spray.
    Medeco Recommends FLUID FILM for Cylinder Lubrication
