Ice water pump torque specs
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by JC91006, May 12, 2014.
  1. dolj
    dolj Senior Member
    8,652
    4,403
    Wellington, New Zealand
    Toe-mar-toe, tuh-may-toe, but it does hit it home to check whether one is using in-lbs or ft-lbs.
  2. Mendel Leisk
    42,361
    Rookie mistake is to misread inch/lbs as foot/lbs, dutifully snap the head off the bolt.
  3. Sonic_TH
    Sonic_TH Active Member
    575
    96
    Puerto Rico
    2016 Prius c
    I think is 20 foot pounds for the 2 top bolts, and 15 foot pounds for the 3 bottom bolts. Can please someone confirm if is the same for the Prius C?
  4. dolj
    dolj Senior Member
    8,652
    4,403
    No idea, you post a lot of Prius c questions and comments here in the Gen 2 forums. You should be posting your questions in one of the Prius c forums? That's why the forums are organized the way they are.
    #24 dolj, Mar 26, 2021
