Iced Lines by the AC Compressor
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TwoPriusInTenn, Jun 27, 2025.
  1. TwoPriusInTenn
    250
    66
    Tennessee
    Greetings,
    2008 - 279,000
    Recently replaced the AC evaporator and had refrigerant and compressor oil added to the system. After running the AC for awhile I noticed ice on the lines by the compressor in the engine compartment. AC is now blowing cool air, but not cold air.
    Bad compressor?
  2. Tombukt2
    Tombukt2 Senior Member
    13,545
    2,440
    Durham NC
    Frozen gas don't move or flow correctly . Is it full lo side 37 to 40 psi running?
  3. TwoPriusInTenn
    250
    66
    Tennessee
    Currenly defrosting. Mechanic checked psi and said system was running finne when they added refrigerant and compressor oil. I do not have my gauges with me to xheck psi.
  4. Tombukt2
    13,545
    2,440
    Durham NC
    Ts of moisture in system this is what vacuuming eliminates . Why it's done . Might need receiver desiccant replaced if you live with AC on for years .
