ICU behavior at high-speed gliding/coasting
Discussion in 'Prius c Technical Discussion' started by Mr. Cool, Dec 20, 2013.
  1. Mr. Cool
    Mr. Cool New Member
    Auckland, New Zealand
    Hello everyone,
    I have recently got a ScanGauge II and it has helped me to confirm my previous observation: when coasting at high speed over 50 mph, the ICE doesn't turn off and idles at around 980 rpm.
    As speed slowly drops, the ICE shuts down when reaching 43.5 mph (70 km/h). Before the ScanGauge I observed it by a noticeable push/hit in the drive-train.
    My question is whether it's originally designed to behave like that or is there a problem with my car?
    Thank you very much in advance.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    That is the way it was designed. The "ICE" will spin above about the speed that you mention to prevent overspeed of MG1.
  3. Mr. Cool
    Mr. Cool New Member
    Thank you for the reply and the correction. But how does the overspeed of MG1 happen? Isn't it supposed to disconnect when gliding (like in neutral)?
    Does it also mean that instead of coasting I should push a throttle a little bit to maintain around the same rpm as it would idle when gliding. Otherwise idling is just a loss of energy.
    It brings us to a question of effectiveness: is it better to glide at high speed when there's a small descent or use throttle a little bit?
  4. TrafficMPG
    TrafficMPG Junior Member
    Unlike a CVT (continuously variable transmission), the synergy drive is a direct drive. The planetary gears use a combination ICE speed and MG1 to create a final drive ratio per se. The system is always connected unless in neutral.
    I personally wouldn't shift into neutral on hills. I can't remember where but I read something akin to it being a bad thing due to the fact that shifting back to D would put MG1 at risk of overspinning. I'll have to test that theory out with the Scangauge.
    Coasting is the ultimate fuel saver - DWB (driving without brakes). With that being said, there are hypermiling techniques that will optimize throttle positions such as pulse and glide and DWL (driving with load). If you do a search you can find dozens of tips.
    Happy driving!
  5. fuzzy1
    10,710
    In Neutral, only the electric fields that drive the MGs are disconnected. All the parts are still physically or mechanically connected, and must still spin. The gearing is such that if the ICE crankshaft is stationary, MG1 must spin very fast. Spinning up the ICE to idle speed allows MG1 to slow to a safe RPM.
    When your foot is off the throttle pedal, the car is using a small bit of regeneration to create synthetic drag, similar to (but weaker than) the engine compression drag of a non-hybrid. This greatly helps drivability for people accustomed to the feel of non-hybrids. But any regeneration creates some conversion loss, so this does not make for the most efficient operation.
    To truly coast in D gear, without this synthetic drag, press the throttle just a little bit. On a Gen2 Liftback, adjust the throttle until the energy flow arrows disappear. On a Gen3 Liftback, bring up the HSI display and adjust until the CHG bar disappears. Your 'c' has different displays (my aging brain refuses to remember all the details), but does have something similar for guidance.
    Be extremely cautious about using Neutral downhill, or just avoid it altogether. In gear (D and B), the car can protect itself from MG1 overspeed. In Neutral, it cannot, and there are ways for the driver to unintentionally destroy it.
    minkus, Mr. Cool and rcortespr like this.
  6. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    The hypothesis of overspeeding MG1 has been discussed since the era of Gen1. However, starting from the Gen3, PiP, v & c, the introduction of SRU has lowered the speed of MG1 and very close to MG2.
    For Gen1 & Gen2,
    MG1 rpm = -2.6 * MG2 rpm when Engine stopped
    For Gen3, PiP, v & c,
    MG1 rpm = - ( 143 / 145 ) * MG2 rpm when Engine stopped
    At 50 mph, MG2 is about 5954 rpm and MG1 could be commanded to spin at -5872 rpm if the engine were to be stopped but instead Toyota chose to spin MG1 at about -2272 rpm. 5872 rpm is hardly the maximum rpm or unsafe rpm so does the overspeed of MG1 hypothesis still hold?
    The PiP has the same PSD & SRU and yet it can run EV up to 62 mph, so why MG1 does not overspeed?
    Vincent
  7. jdcollins5
    5,131
    1,346
    Wilmington, NC
    This is the explanation I have always seen given for the reason that the Gen 3 ICE will run above 46 mph. If this is not the reason then why would you think Toyota would run the ICE above this speed?
    I always wondered why the PiP could run up to 62 mph in EV too. Hopefully someone can come along and explain this to us.
  8. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    A lot of power would be drawing from the HV battery above 46 mph. It would put more stress (charge/recharge cycles) on the battery and may not reach 10 years / 150k miles warrenty. That's my speculation.
    I bet the engineers figured that is also when gas engine can be very efficient.
    PiP battery was design to handle up to 62 mph.
    jdcollins5 likes this.
  9. Mr. Cool
    Mr. Cool New Member
    Thanks everyone for your replies. But my another question still stands unanswered:
    I've noticed that when an engine idles at 50mph (around 980rpm, car gliding), ScanGauge shows instant consumption around 1 Lkh. If I apply throttle just a little bit I can get instant fuel consumption at around 1.6-2 lkh, though more fuel burned, it at least propels a car and not being wasted. Am i right? Is there a flaw in my reasoning?
  10. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Just let it glide. If you throttle a little, gas engine makes about 5-7 kw. Per the BSFC engine map, that is not an ideal efficiency. Ideal is only reached at min of 10 kw.
    That's my observation on my PiP. C maybe the same or slightly different.
  11. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    This is incorrect. The system is always connected. In Neutral no electrical power is applied to M/G1 or M/G2, but the gearing is still connected. There is no clutch in the Prius, so the mechanical gears are always connected.
    This simulation shows the relation of M/G1, the engine, and M/G2. M/G2 is linear with the speed of the tires.
    Toyota Prius - Power Split Device
    The Prius being emulated is a Gen 1, not a c, so some numbers will not be exact, but you will see the same effect of the engine rotating being mandatory in the 40s.
  12. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Good catch jimbo.
    Nothing gets disconnected, even in Neutral. No clutch and very simple.
  13. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    The HSI in the c is prettier and in colour, but it is functionally identical to the HSI in a Gen III, so the advice is the same - adjust pedal input until there's no charge bar (or positive bar).
  14. Matt H
    Matt H Active Member
    164
    105
    Okinawa Japan
    2012 Aqua
    FWIW, how fast the car will go before the ICE comes on is subject to SOC of the traction battery. With a high SOC, the highest speed I've attained without ICE is 82 km/h (51 mph). You must accelerate slowly up to that speed. If decelerating, the ICE won't kick out until you're going quite a bit slower.
  15. minkus
    minkus Active Member
    369
    125
    Cleveland, OH
    If you're going above 42 mph and take your foot off the gas, fuel will be cut off but the ICE will continue to "run (pump air), hence no "EV" light. The energy flow meter will confirm this. In the same scenario, you can lightly press the gas pedal to do a "true coast" (no regen or propulsion). If you very gently push the pedal beyond that, the energy flow diagram will show power from the battery but no ICE power.
