ID an undercar front splash guard/cover
Discussion in 'Gen 3 Prius Main Forum' started by Franklyn Wu, Jul 14, 2021.
  1. Franklyn Wu
    Franklyn Wu New Member
    Berkeley, California
    I need to replace these undercar splash guard/shield but I don't know what they are called exactly to buy the correct part. Can someone kindly tell me what they are called, and better yet, a link to buy the correct replacement? It's the part circled in red.
    Thanks in advance!
  2. Mendel Leisk
    40,584
    IIRC, the "part" is what you've circled, plus the continuation, the plastic liner that goes all the way around the wheel well. There's a "bolted" connection between the two, but it's considered a single piece. And trust me, after a few years, those bolts are solid lumps of rust: try to unscrew them and the bolt heads snap off.
    You should be able to find the part on online sites, like McGeorge Toyota Parts (US), or Amayama (International, sourcing through Japan or UAE).
  3. Franklyn Wu
    thanks. Do you know what this single piece is called?
  4. amarino
    amarino Active Member
    134
    102
    99
  5. rjparker
    rjparker Tu Humilde Sirviente
    9,597
    5,893
    Texas Hill Country
    A junkyard might be best since you get a factory part for a fraction of the cost. You may be able to replace only that piece. Aftermarket covers exist and are cheaper but they are flimsy. Having the right pushpins and bolts is 2/3 of the solution.
  6. Franklyn Wu
    I think the part is front passenger fender liner
