Idea: Low Coolant Sensor to Prevent Head Gasket Failure on Gen 4 Prius
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by PatrickL, Sep 19, 2025.
  1. bisco
    51,901
    idk what they are
  2. Doug McC
    Doug McC Senior Member
    1,079
    417
    Midwest
    2022 Prius
    Assuming a reasonable daily commute, I seriously doubt your logic. The weld that caused the issue doesn’t catastrophically break, but begins as a crack, that may grow over time. Now if someone has actually experienced the pipe having a sudden catastrophic and complete break or bursting I would be very surprised. And if such a break were to occur all the level monitoring in the universe wouldn’t do any good.
  3. Doug McC
    1,079
    417
    Midwest
    2022 Prius
    Another thought: install all these monitors to monitor coolant levels, brake fluid, oil levels, etc. to avoid that torturous task of popping the hood. Since that is such a pain, you better go with the camera and microphone to monitor for mice making a home under there too. Wait:! I have a better idea! Install a biological presence monitor to detect unauthorized life forms! Then you would know if someone was trying to remove your catalytic converter! But then, you’ll still have to check the air filter once in awhile. Darn. :rolleyes:
  4. Leadfoot J. McCoalroller
    8,081
    7,560
    Pennsylvania
    2018 Prius c
    It might be. Some of those little cams have useful night vision built in. Couldn't say for the one I screenshotted- would be an experiment. But if you're going to wire in a little wifi camera to your underhood 12v supply, it would be trivial to also add a little LED taped to the opposite side of the reservoir so that it made a good contrast through the bottle and coolant (if any)
  5. bisco
    51,901
    let's face it. most car owners don't ever check anything, and many dealers probably don't when it's in for service
  6. PatrickL
    PatrickL Junior Member
    San Diego
    2018 Prius
    hence the idea
    Mendel -- totally agree that fixing the leak source is the right answer.
    If there’s an EHRS/exhaust-side manufacturing defect (or any hard-part failure), that should be diagnosed and repaired. My point isn’t to avoid the fix; it’s to add a cheap early-warning layer so owners don’t learn about a leak only after the head gasket is cooked.
    Why an early-warning sensor still helps (even with known leak modes):
    • Leaks don’t announce themselves on a schedule. A pinhole that opens on a hot day, a failing cap, a hose clamp, a slow seep at the water pump--any of these can drain a reservoir long before a MIL or temp light fires.
    • MIL is late for level-loss. By the time the dash warns, the system may already be ingesting air and spiking temps under load. An earlier alert at the tank buys time to pull over and save the engine.
    • Complement, not substitute. Think of it like a smoke detector. It doesn’t fix wiring; it buys you time to keep a bad situation from becoming catastrophic.
    If EHRS defects are common, great--then we can be specific:
    If you’ve got a TSB/campaign/article that documents those weld failures on Gen 4, please link it. That actually strengthens the case for an early-warning kit: a known failure mode + a simple alert = fewer totaled engines while owners schedule the repair.
    Design thoughts to avoid false alarms (and slosh):
    • Dual-threshold + debounce: Trigger only when level is below a set point and remains low for, say, 10–20 seconds (ignores slosh).
    • Temperature gating: Only monitor when coolant is warmed (prevents “cold contraction” noise).
    • Self-test & fail-safe: Periodic test pulse; if sensor/wire fails, it warns “sensor fault” (not silent).
    • Non-invasive install: Float switch or capacitive probe at the reservoir, add-on buzzer/light in cabin. No CARB/EPA entanglement since it’s not emissions-control--just a warning.
    Who benefits:
    • People out of warranty, high-mileage drivers, rideshare/delivery folks (lots of heat cycles), and anyone far from a dealer. A $100–$200 kit that prevents a $3–$5k repair is basic risk management.
    Happy path (both/and, not either/or):
    1. Diagnose/repair the leak source (EHRS, pump, clamps, cap, hoses, HG, etc.).
    2. Add an early-warning level sensor so the next issue doesn’t escalate unseen.
    If you happen to have links or TSB refs on the EHRS issue, that’d be super helpful for owners and for calibrating the alert threshold.
    #26 PatrickL, Sep 21, 2025
  7. bisco
    51,901
    exactly why it's brilliant
    PatrickL likes this.
  8. bisco
    51,901
    if you own a susceptible gen 4 that hasn't leaked yet, or are interested in buying one, it seems like a no brainer, as it is the number one issue on these models
  9. BiomedO1
    BiomedO1 Senior Member
    3,585
    1,856
    SacTown, Ca
    So you just depended on your mechanic to do EVERYTHING for you? If you just take your car to jiffy-lube or Walmart for oil changes, they're suppose to check your fluid levels; but do they??? In most cases, they are high school or recent high school graduate, basically wannabe auto mechanics.
    You simply open the hood, look at it, close the hood. It literally takes 15 seconds. Sorry that happened to you, but you know that was preventable. As I stated earlier, I was always told to check oil and fluids at every gas fill-up. I've taught all my kids the same, including making them swap out a spare tire. Very easy to do when they want their drivers license and a car. They had to demonstrate to me that they have basic car knowledge for me to match anything they put down for their car. The youngest one got me for five grand. She's smart, patient and frugal. I'm proud of all of them, especially her.
    Better to know it and not need it - than to need it and not know it..............
    #29 BiomedO1, Sep 21, 2025
  10. rjparker
    rjparker Tu Humilde Sirviente
    10,139
    6,300
    Texas Hill Country
    The TSB covering 2016-19 gen4s simply says pressurize and look for a leak visually or with a borescope. If found in the heat exchanger replace the entire assembly including cats.
  11. Mendel Leisk
    41,425
    ^ It’s somewhat arduous, requires disconnecting the rear portion of exhaust.
  12. BiomedO1
    3,585
    1,856
    SacTown, Ca
    Some get misdiagnosed as a blow head gasket, because mechanics are so used to the gen3s doing that. It's not like they're going to admit their misdiagnoses when they find the head gasket intact and eat all the labor cost - they'll just say that the exhaust gas heat exchanger was defective too. We're doing you a favor, because we got that covered under warranty.:mad::(
    Everyone's happy; dealer didn't have to eat the non-head gasket issue and the customer is happy to get a $2K part installed for free....
    #32 BiomedO1, Sep 22, 2025
  13. Mendel Leisk
    41,425
    To muddy the waters: protracted, overlooked coolant leak, due to the exhaust heat recovery system, can run the engine dry and cause head gasket failure.
  14. rjparker
    10,139
    6,300
    Texas Hill Country
    Except for California and the few carb States enforcing California standards, the 8 year or 80,000 mile warranty is basically expired on all 2016-17 models on years alone and expired on most of the 2018/19s on miles.
    The removal and install is all bolt on which is pretty easy with a lift.
    Realistically it seems silly to buy a new one on your own dime when the cats are still good and a bypass is within everyone's reach at zero to $20.
    #34 rjparker, Sep 22, 2025
  15. BiomedO1
    3,585
    1,856
    SacTown, Ca
    just a FYI - CARB states get 15 years or 150K miles
  16. PatrickL
    San Diego
    2018 Prius
    Why can't a prius have a similar coolant level warning system as the bmw?
  17. BiomedO1
    3,585
    1,856
    SacTown, Ca
    Because you can simply 'eye-ball' it. Adding sensors for all possible outcomes gets expensive; because someone will have to program it and find some place for the icon or trigger a nonsensical trouble-code.
    That's part of the reason you pay 75% more for a BMW or MBZ. Bargain basement means a bit more hands-on. If you want someone else to deal with it; you better be willing to pay them...
    Doug McC likes this.
  18. rjparker
    10,139
    6,300
    Texas Hill Country
    There is a cost and complexity added when adding monitors to a cooling system that was nearly bulletproof even on the problematic gen3 1.8Ls.
    The biggest bang for the buck would add an audible alarm on abnormal temperature rises before at damaging limit (say 215f) and a direct temperature readout to one of the two existing temperature sensors. Probably the block sensor since it would have coolant longer.
    All available for $35 with configurable alarm points. I use one for this purpose (early audible with readout to learn trends) and also set an audible for the highest speed I want to drive.
    If I had an early gen4 I would carry a bypass hose and tools necessary. I would also shutdown and tow if the factory light blinked and I managed to see it.
    BiomedO1 likes this.
  19. BiomedO1
    3,585
    1,856
    SacTown, Ca
    FWIW; I had an amazon link to that in post #2 - that a pop-up blocker may have removed.
    #39 BiomedO1, Sep 23, 2025
  20. PatrickL
    San Diego
    2018 Prius
    Your 75% more for bmw would not translate to increasing the price of a prius to that degree if all that was done was add what might be $100 part to the coolant tank. A 2018 Prius tells me how close I am to the parked car in front of me, it tells me there is someone in my blind spot, it tells me if there is someone too close behind me, so wny not a coolant level sensor? Do I have to check it every time I pull up for gas? What about the ladies, they don't really like lifting hoods, at least my gal doesn't.
