Idea: Low Coolant Sensor to Prevent Head Gasket Failure on Gen 4 Prius
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by PatrickL, Sep 19, 2025.
  1. bisco
    51,901
    marketing to people who never lift the hood may be the biggest challenge
    Tande likes this.
  2. BiomedO1
    BiomedO1 Senior Member
    3,585
    1,856
    SacTown, Ca
    OK, you've got a great idea that's going to make you a millionaire........
    Go with God......
    Doug McC likes this.
  3. PatrickL
    PatrickL Junior Member
    San Diego
    2018 Prius
    Probably not, I know very little about cars, and I just found a nice work around, install a cheap OBD 2 sensor in the OBD port under the dash, that with Dr. Prius app, which gives you temperature readings much better than waiting for the temp light to turn red, which is often too late on my prius. Still, a low coolant sensor wouldn't be a bad idea, methinks.
    Iron Man Prius and bisco like this.
  4. PatrickL
    San Diego
    2018 Prius
    How bout installing a cheap OBD 2 sensor in the OBD port under the dash, that with the Dr. Prius app should give better temperature warnings than waiting for the Prius temperature light alert to trigger red, which is too late, eh?
  5. Brian1954
    Brian1954 Senior Member
    2,194
    863
    South Central PA, USA
    The Dr Prius app does not show the engine coolant temperature. It shows three temperatures for the hybrid battery.
    The best way to monitor the engine coolant temperature is shown in posts #2 and #38. I have the P10 display connected to the OBD2 port , as shown in post #38. I installed it three years ago based on rjparker's recommendation. I could not be happier.
    #45 Brian1954, Oct 8, 2025
    BiomedO1 likes this.
