Idea to fool the tire pressure sensors
Discussion in 'Gen 3 Prius Accessories and Modifications' started by CivicQc, Mar 4, 2010.
  1. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    I found some interesting info on this subject at this link Toyota TPMS - Toyota TPMS Tools & Tire Pressure Monitoring Systems
    "The sensor measures the pressure and temperature in the tire and transmits this data along with the unique ID of the TPMS to the tire pressure monitor ECU/receiver."
    "Before attempting to replace a Toyota TPMS we advise the use of one our Bartec Wheelrite tools to establish the need for replacement and the nature of the fault. This may support a warranty claim but will also ensure that the dealer or tire shop is covered for liability claims. The legal position is that as soon as the dealer breaks down the wheel then he becomes liable and cannot allow the car to be driven away from his shop with the TPMS warning light still on. Many dealers have found that customers will not accept the costs for repair and may attribute any breakage to the dealer if there is no audit trail."
  2. pEEf
    pEEf Engineer - EV nut
    720
    579
    Berkeley, CA
    If you do my simple "paperclip" hack, the light will be off, and there are no codes.
    4 people like this.
  3. bear15
    bear15 Member
    168
    35
    Suburban Chicago
    pEEf, How would you do this trick with a gen II Prius?
    Thanks
    PriusGuy32 likes this.
  4. bzyrice
    bzyrice Active Member
    805
    324
    West Palm
    Hmmm may jump the wire if I get aftermarket wheels used.. Thanks for this post!!
  5. justintiime
    justintiime Junior Member
    64
    Moneta, VA
    thanks to this thread, I wont need to put TPMS in my summer wheels! Its a shame I already bought the TPMS though.
  6. bzyrice
    805
    324
    West Palm
    I went to the tire shop with my wheels and they swapped the tpms for mr for 20.00.. Just to give u guys an idea of the cost..
  7. Den49
    Den49 Member
    498
    272
    Maryland
    I don't plan to buy aftermarket wheels, but this fix will also work when a sensor fails electrically if you don't consider it worth the time and money to replace it just to get the light on the dash turned off. Tire pressure monitoring is the one safety item that, in my opinion, is unnecessary for people who check their tire pressure regularly.
    Thanks pEEf for posting this solution.
  8. Redryder
    Redryder Junior Member
    NH & NS
    Boy, Thank You pEEf for saving me time and money. As a new Prius owner I was surprised the efforts (and expense) you had to go through twice a year if you were swapping out snows on rims and summers on rims just to avoid a light coming on. I always check my tire pressure and rely more on my eyesight to read a gauge than a a computerized analysis.
  9. ETC(SS)
    7,139
    Just sayin.... :D
    Coffee Dude likes this.
  10. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    Funny but a paper clip is cheaper than tape.
  11. evtran
    evtran New Member
    58
    This was a great thread and provided a lot of information on a stupid problem..:) The following link provides more information from a Tire shop perspective. I hope the link works.
    What I got from the link is that its not illegal for the shop to install wheels without TPMS, but it is illegal for them to disable the warning light. Apparently from the link below, a warning light indicates the TPMS system is working. So if you get in an accident with Tires/wheels without TPMS installed, But your TPMS system/warning light is intact, you are good. I hope this helps.
    TPMS / TPWS
  12. Judgeless
    1,821
    257
    Cleveland, OH
    It is not illegal in any state. It is a liability for the shop. They do not want to get sued if something happens.
  13. evtran
    evtran New Member
    58
    It is Illegal for the shop to disable your TPMS system. But not illegal to sell you tires/wheels without TPMS sensors. Thanks.
  14. Judgeless
    1,821
    257
    Cleveland, OH
    I disagree. There is no law in the US that makes it illegal for a dealer or a tire shop to disable the TPMS using an electronic tool, hardware or anything else. It is strictly a liability.
    What do you thing the penalty is? Third degree felony? LOL
  15. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    It is illegal to disable the TPMS light per FMVSS 138. Actually FMVSS 138 establishes the requirement for TMPS. An older law prevents disabling any safety system:
    A good write-up about TPMS law can be found at this link:
    Tire Review - The Final Word: NHTSA Clears the Air on TPMS Regs and Plus-...
    While there is still some legal debate, the general answer is that a tire shop can install wheels lacking TPMS, but they cannot disable the warning light.
    Tom
  16. El Dobro
    El Dobro A Member
    7,088
    3,270
  17. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    Ok so this is to disable the TPMS light in the Gen3 Pri. Got it.
    A web search reveals similar procedures for the Yaris, RAV4, etc... but not for the Gen2 Pri?!
    Does anybody know where the TPMS module is in the Gen2 Pri? I'd be more than willing to explore with a multimeter and see if I cant get the stupid light off in my Gen2.
    This could be a worthwhile endeavor for us Gen2 owners!!
  18. usando
    usando Junior Member
    Toronto, Canada
    MAX2 and PriusGuy32 like this.
  19. Porkenstein
    Porkenstein Junior Member
    Greeley, Colorado
    Blame it on the government who thinks they need to be in every part of our lives. If you cant keep the correct tire pressure in your car by checking it then you are too stupid to be driving.
    Bohemian Grove likes this.
  20. PriusGuy32
    1,417
    514
    I ended up buying a mini-VCI cable on ebay and using that to shut off my TPMS light (y) Now I program my sensor ID's and can monitor the battery levels of each sensor, etc. I highly recommend it!!
