Idea to fool the tire pressure sensors
Discussion in 'Gen 3 Prius Accessories and Modifications' started by CivicQc, Mar 4, 2010.
  1. Malosos
    Malosos Member
    117
    33
    Los Angeles
    Got it right guys thanks for the input, here's how it should look...
    Ven, Serval, Bohemian Grove and 3 others like this.
  2. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    Just what I needed! fwiw, it was almost the exact same procedure to do this on my 2005 Toyota 4Runner as well. Thank you!
    The reason I want to do it is I already replaced the factory sensors around year 5 with a full set from Town Fair Tire. The OEM ones were 4 times the price and 2 of the 4 had a dead battery (or some other failure). The Town Fair ones don't appear to have lasted nearly as long and I have at least 1 that is faulty (as indicated by a solid TPMS light). What's weird is that sometimes the light goes off and stays off for a few days. Then it will come back on, blink for a minute, then go solid.
    So since my car is over 8 years old, over 150k miles, and I know how to check my own tire pressures, I'd just as soon do away with the dash light so I don't have to be hassled at my yearly inspection.
  3. wjtracy
    wjtracy Senior Member
    11,367
    3,608
    Northern VA (NoVA)
    My memory is bad, but if I recall Gen2 does not have a good way to hack disable TPMS.
    I found a way to give a fake reading with a binder clip, which I used for a couple years until we finally got new TPMS all around,
    Some of mine OEM lasted 12 years.
  4. Mendel Leisk
    41,418
    I got new tires last fall, put them on about a week back, and the tpms sensors were all recognized, no light. As far as I know (it was Costco), they did the rebuild kit, where the replace washers, and maybe the valve?
    If and when they fail I don't really care, will probably just replace with regular, at the next tire replacement, if that ever happens. Still, in Canada regulations are more lax I believe? TPMS were not mandatory, last time I checked.
  5. kumatae
    kumatae Member
    101
    So Cal
    2014 Prius v wagon
    This mod is brilliant. Just did it on my Prius V after the 17 inch upgrade did not have TPMS sensors.
    Here’s a tip. A staple works just as well as a paper clip. The staple goes in the hole just about perfect and is almost the perfect length as well. Just need to cut 1/4 of an inch. I added a piece of electrical tape to be safe.
    Much thanks!!
    Bohemian Grove likes this.
  6. BikesOhio
    BikesOhio Junior Member
    Cleveland
    Is this jumper placed in the tpms ecu? Or into the wiring harness connector ? Paper clip seems too thick. I was thinking of shorting the black and purple wire in the harness?
  7. wjtracy
    11,367
    3,608
    Northern VA (NoVA)
    ...not sure @pEEf is still active here
  8. Ven
    Ven Junior Member
    Weymouth, MA
    Just did this with a staple and put a tape over it. Worked like a charm!
    Make sure to use the round smaller holes. Sharing knowledge like this is what makes this community so great!!
    Thanks everyone!!
    Malosos, m.wynn and wjtracy like this.
  9. apollo1
    apollo1 New Member
    BC
    Is this the wiring harness connector that we're putting the paperclip into? Or the ecu itself? In that photo it looks like the connector (but I haven't taken my glovebox apart yet), just don't really understand how that works, would have expected it to be the ecu. Would like to confirm before trying. Thank you
  10. Hobbgoblin
    Hobbgoblin New Member
    Missouri
    I signed up to clarify this for others since I know the post is old. Sorry if there is a more formal guide on this already but my searches came up with nothing.
    Do this with the car off. You are inserting the jumper/paperclip/staple into the plug itself AND leaving it unplugged. In my instance I used a staple bent into a U, tested by just turning the car to the on position and verified that it was correct, then I taped off the connector with electrical tape. It will be off instantly when you turn it on, there was no blinking or delay. It was just off. All other lights on dash are fine.
    My question as I am a dummy with electrical. How long has anyone ran with this. Just curious. I didn't want this like melting behind my dash or something. I wouldn't think it would do anything....
    Malosos likes this.
  11. unigeezer
    unigeezer Member
    228
    63
    torrance, ca
    Got it!
    #131 unigeezer, Nov 18, 2024
    wjtracy likes this.
  12. StarCaller
    StarCaller Senior Member
    1,277
    729
    Cedar Crest, NM, USA
    wjtracy likes this.
  13. Eamon
    Eamon Junior Member
    Marina Del Rey, California
    I just tried this hack, but I think I jumped 2 and 12 and I now have a warning message stop vehicle and check hybrid system and the power steering is out and I have Christmas lights on the dash.
    What should I do?
  14. Eamon
    Eamon Junior Member
    I found the fix, it's post #10 of this thread.
    I apparently blew a 10A fuse "ECU-IG NO 2" under the driver side foot well. Replaced it and cleared the codes I got multiple, U0129 and U0131 codes, and everything went back to normal.
    The cause was I jumped pin #2 and #12 and used the large hole instead of the small hole.
    After changing the fuse clearing the codes, I jumped pin #5 and #7 using the small holes and left the tpms unplugged, and the tpms light turned off instantly.
    Thank you all for your help!
    priumium and Grit like this.
  15. Mendel Leisk
    41,418
    In other words you've left a wire in there, bridging between those two? Don't neglect to remove it when trading/selling.
    All in all, a lot of effort, for something that didn't even exist 10~15 years back. And not to fix it, just to kill the light.
