Ideal Charging Schedule
Discussion in 'Prime Plug-in Charging' started by epon, May 5, 2017.
  1. epon
    epon Junior Member
    17
    Az
    New to plug-ins and driver in household has a 6 - 10 mile daily round trip commute. On days they arrive with 60% or more battery left should the charging be postponed to the next night to save the charge cycles? I assume topping up the battery nightly isnt ideal. Also saw something about them preferring to live in a state of lower charge. A quick and dirty guide or a pointing to one would be appreciated. TIA
    49,520
    correct on all counts. delay charging when ever convenient, but don't go crazy. the big thing is not to leave it charged for long periods of time.
    i keep mine about 50% charged most of the time, so if i do need to run out, it only takes a half hour to fill it. that's with an L2 charger, and prime would take a little longer, if you need the full 25 miles.
  3. Prius from Dad
    Prius from Dad Senior Member
    724
    1,115
    Toms River, NJ USA
    There is a charging schedule you can set to your departure time (preferred method). Your battery will not be sitting at full charge for more than a half hour. If it is a consistent commute you can set a weekday schedule and charge as needed on the weekends.
  4. ForestBeekeeper
    ForestBeekeeper Active Member
    717
    276
    Maine
    We live about 11 miles from town. A round trip is ~22 miles. In winter with the defrost going we only have 20 miles on a full charge. Now that we are going into summer a full charge is easily 24+ miles.
    We keep it plugged-in all the time at home.
    joachimz and priuscatprimeguy like this.
