Ideal Prius Jack Stand Size
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Siward, Oct 10, 2018.
Tags:
  1. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    Neither, why? The "he" you refer to is not the OP, so not to whom I was responding.
  2. Mendel Leisk
    42,345
    Going up on ramps is something I haven't done in at least 30 years.
    It always made me nervous: no matter how carefully I lined them up, in the back-of-mind I was thinking about slipping off the sides, or going over the ends. And almost without exception I want to raise the front in the confines of a garage, maybe even when the engine's cooled down.
    So I stick with jack and safety stands, plus wheel chocks fore and aft, on the wheels still on the ground. Whenever practical I also push this big tree trunk section under first, under a solid/strong portion: my safety net in case something goes south.
    Raytheeagle likes this.
  3. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Here we prefer to be hand fed, goo goo gaa gaa.
    05PreeUs likes this.
  4. ASRDogman
    ASRDogman Senior Member
    8,066
    4,086
    I just jack on side for oil changes, that's easy. But for doing the transmission fluid change ramps in the front
    then jacking the rear with stands would be MUCH easier and FASTER!
