Ideas for a reliable alternative to Leviton - need help and ideas.
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by DianneWhitmire, Sep 4, 2012.
  1. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    I don't know anything about Leviton's EVSE and how yours is installed, but in the future, is there any way you can check the voltage of the outlet (if the EVSE is plugged in) or the wiring itself (if it's hardwired)? You can buy a cheap volt-ohm meter/multimeter for <$10 at say Harbor Freight Tools or Fry's Electronics. At least that way you can see if the EVSE is actually getting power and/or loses it.
    I had a Nissan-branded Aerovironment L2 EVSE in my possession (that I sold to devprius) and it required hardwiring. IIRC, it looked pretty trivial to remove the front cover (it's wasn't screwed on anyway when it came new) and put a multimeter on the terminals to confirm whether there was any voltage.
  2. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    There's a vanity-ring that covers the 9 or so front-panel screws and according to my electrician, it's a pain to remove the ring. But once the ring and screws are off, it does indeed look pretty simple to use a multi-meter to test voltage coming in.
  3. pineprius
    pineprius 15th Hole #4
    245
    134
    NC
    Dianne,
    Now that you have us all convinced Leviton has poor customer service, what exactly was the problem at your dealership? Obviously not the charger, what was it? It would be helpful for the rest of us to know, so we don't repeat your mistake and struggle if it happens to us. So far, our Leviton is working perfectly. Hopefully it stays that way.
  4. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    The charger is inside the car. The Leviton unit is an EVSE.
  5. pineprius
    245
    134
    NC
    Yes, I understand the difference. I was using Dianne's verbage in her original thread, subsequently changed to "box". Seems to me blaming where the blame isn't due might be part of the problem at Carson Toyota. Sounds like someone flipped the breaker and didn't tell her, unless she fesses up.
  6. cocopupu
    cocopupu Junior Member
    california
    there is a company called phatenergy that makes a solar carport
  7. rockerdan
    rockerdan PiP Rocks!
    427
    83
    Wheatfield NY
    Now that would be nice....a solar carport to not only keep your car dry/clean...but charge it for free....now we are talking!
    Link?
    Dan
  8. cocopupu
    california
