Ideas on pulsing raspy brake noise?
Discussion in 'Generation 1 Prius Discussion' started by Wisco, May 1, 2014.
  1. Wisco
    Wisco Member
    116
    Hello,
    Our gen 1 has developed a (currently minor) noise issue when braking. I'd like to sort it out before it becomes serious.
    The brakes are still strong, and the regenerative system appears to be working. When the brakes are applied (even gently) there is a pulsing raspy sound, seems like it is coming from the front, driver's side. It is more rapid at higher speeds, and louder during rapid deceleration. I guess I'd call it 'grinding', although this is much less unpleasant than the classic 'grinding brakes' I've heard on other cars.
    In any other car I would figure a warped rotor or worn out brake pad. But I had imagined that the regenerative system handled light braking, and conventional brakes took over beyond a certain threshold. Now I'm hoping they work in tandem, even on gentle braking and this is just a boring, simple pad issue.
    Is there anything specific this sound could suggest?
    I'll be putting our summer wheels on soon, is there any easy way to narrow this down?
    How challenging is gen 1 brake work? Within the capabilities of a careful do-it-yourselfer?
    Thanks!
  2. usnavystgc
    3,159
    989
    Tucson, AZ
    Well, brake work is a very generic term. Can you change the rotors and pads just like any other car? Yes! Can you turn the drum and replace the shoes just like any other car? Yes.
    I'm guessing your problem is a warped rotor or a rusty one. You might try going down a secluded road at about 40 mph and hitting the brakes hard. Or if that scares you, back up with the brakes lightly applied (use two feet, one on the brake, one on the gas). In reverse, the regenerative braking system is disabled so all braking is done by friction. Doing this will get rid of the rust on your rotor if that's your problem. If not, take off the wheels and look at your pads. My pads on my 01 were so old, they literally fell apart one day. Yours might have done the same.
  3. Wisco
    Wisco Member
    116
    Thanks for the advice, I'll give that a try. Good to know I'm headed in the right direction.
    Seems most of my questions on this forum are 'I'm having problem X, which seems like it is caused by Y. But I'm worried something else is going on because it's a hybrid'
    The response I get (and need) is 'relax, it's just a car'.
    I guess most of the problems are just regular old car problems, and not caused by the flux capacitors or warp nacelles.
    usnavystgc likes this.
  4. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    You could drive about 40 mph, then put the car in neutral and stop. At least in the gen 2, it turns off the regen and uses just the pads and rotors to stop
  5. usnavystgc
    3,159
    989
    Tucson, AZ
    Ah yes, I forgot about the neutral thing and yes, that applies to the Gen I as well.
  6. Wisco
    Wisco Member
    116
    Bingo!
    After some backing up while braking, the sound is gone! Problem solved and lesson learned for next time.
    Thanks for your help.
    usnavystgc and Aaron Vitolins like this.
  7. Wisco
    Wisco Member
    116
    Well the problem has gotten worse. In addition to the noise, the car shudders while braking. I can feel pulsing in the pedal when I brake.
    I pulled off the FL wheel, and found that the rotor has a rough patch on 1/4 of the surface. I tried to scrub off the rust, but I don't think it was effective.
    So I guess I'm shopping for a rotor..
  8. ChapmanF
    15,533
    If you carry that roughish rotor into your friendly neighborhood Carquest or similar shop, along with its brother from the other side, they'll probably stick both of 'em on a lathe for you and hand you back two smooth flat rotors for about $30. The only reason they couldn't do that would be if they're so heavily worn that the lathe would cut them thinner than the minimum thickness, which is highly unlikely on a Prius because it makes such little use of the brakes. Or if they're especially badly warped. They can tell you that before putting them on the lathe.
    You'll naturally want new flat brake pads to press on your newly flat rotors.
    If yours are at all like mine were, you might find that the inner surface (the one that's hard to see without taking the rotor off) has a strange wear pattern where only about the middle 2/3 of the pad was touching.
    -Chap
  9. bwilson4web
    15,513
    Don't rule out wheel bearings.
  10. Wisco
    Wisco Member
    116
    Thank you both, I'll see if anyone in the area will resurface the rotor(s).
    The pulsing only occurs when braking, I had assumed that ruled out the bearings, but perhaps that was premature? I'll check if they are sloppy next time I lift the car.
    Thanks again.
  11. robert mencl
    robert mencl Member
    173
    49
    hartland me
    2002 Prius
    I
    ABS kicking in?
  12. ChapmanF
    15,533
    The most enduring lesson I learned from my own left front bearing going last year was how completely unable I was to diagnose it with the car in the air. With mine, the only symptom I was having was a noise (growl or hum), and only in real driving conditions with the weight of the car on it. I must have jacked up the car half a dozen times over as many months ... because the noise kept getting more noticeable, so I kept thinking "all right, by now it must be bad enough that I'll be able to tell which one it is with the car up." Nope.
    I was also surprised that I couldn't pick out the bad one by temperature either ... I was sure it would have to be measurably warmer after driving some distance, but it wasn't.
    The one thing that finally nailed the diagnosis for me was a wireless stethoscope I could listen to inside the car while driving ... setting it up took a bit of time, but once I was rolling down the road comparing the pickup channels, I had my culprit within, like, five seconds.
    Four years ago when my right rear went, it did eventually get bad enough that I could tell which one had the problem by spinning the hub while jacked up ... that one felt noticeably "notchy".
    -Chap
  13. Wisco
    Wisco Member
    116
    Doesn't seem like it.. the pulsing occurs with even moderate pressure, when I wouldn't expect ABS to engage. The frequency varies with speed, as well.
    The local Orielys will resurface rotors for $13. I might even get to it this weekend. I've found several guides that should keep me out of trouble.
    Penny-pincher questions:
    Is there any mechanical reason to do the rotors in sets, or can I just resurface the suspect (FL)?
    The pads look thick. Can I reuse them if they are evenly worn? I realize it's a convenient time to do it, but I'd rather save a few bucks and not open up any components I don't have to.
  14. ChapmanF
    15,533
    Rotors and pads tend to develop a shiny "glazed" surface over time, with different frictional characteristics. If you have a rotor resurfaced, it won't have that, and you don't want to start clamping on it with old glazed pads. IF there is absolutely nothing wrong with the pads (they are thick, and totally flat, well bonded, etc.), you can deglaze them with 150-grit sandpaper by hand (don't breathe the dust), but that'll take longer than just putting new ones in.
    If you do just one side, you'll have differences in friction between sides while braking. IF there's absolutely nothing wrong with the pads and rotors on the other side, except for glazing, the 150-grit hand sanding works for rotors as well as for pads (learned from an old 1984 Ford shop manual, so it's official) ... but takes a fair bit of patience. You have to take the rotors and pads out anyway to do it.
    Chances are that the "IF they are perfect" qualifier does not apply to you given the age of your car. I'm guessing you might find, as I did, that the inner pads and inner rotor surfaces are meeting in a narrow track and the pads are no longer flat but stepped at the edges. You definitely don't want to re-use those or they will start right away at wearing your newly-surfaced rotors into the same shape again.
    I would urge just surfacing both rotors and changing all four pads ... you won't regret it.
    I've also read reports of some pads having thick linings left, but the bond failing between the lining and the metal, just because of age/environment and not wear, with the lining being ejected from the brake. It has never happened to me, but I think there are reports in this forum. Maybe the Prius is one of the few cars where pads last long enough for that other weird stuff to happen, just because they wear so slowly.
    When I first bought my car (used, at 126,000) I measured the pad thickness, and again the next year and the year after that, and was able to plot the wear and see that they would probably hit the minimum thickness in 2017. That was cool, but I ended up changing them last year anyway because of the narrow-inner-track, stepped-wear issue (which I had not noticed before because I was only measuring the visible edges) and it's kind of nice to know I did.
    -Chap
    robert mencl and ftl like this.
  15. usnavystgc
    3,159
    989
    Tucson, AZ
    Yes, please do both sides and replace the pads. You will not regret it.
  16. Wisco
    Wisco Member
    116
    Fair enough, I'll do it right. :)
  17. Wisco
    Wisco Member
    116
    The repair went great. The car stops much better and the noise and pulsing are gone. That was much easier than I expected it to be.
    I put a video up, in case anyone else does this repair.
    Thanks again.
    P.S. While the car was in Park and on jack stands I noticed that the front wheels spun freely. Shouldn't they be locked?
  18. ChapmanF
    15,533
    There's a differential sitting between the two drive axles, which means the average of the two wheel rotation speeds must be the same as the transaxle final drive speed. Being in Park locks the transaxle, so the only way either wheel can spin is if the opposite wheel is spinning the same speed in the opposite direction (so they average to zero, since the tranny is locked). That's what you're doing if you spin one wheel by hand while they are both off the ground. :)
    -Chap
  19. Wisco
    Wisco Member
    116
    Another mystery solved, thanks Chap.
