Ideas to prevent unnecessary ICE startups in winter and rain
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by iplug, Oct 22, 2012.
  1. iplug
    iplug Senior Member
    2,455
    1,703
    Rocklin, CA
    With colder weather upon us here in the States, many of us are experiencing ICE startup with turning the cabin heat on or trying to defrost the front windows. The seat heaters go a long way towards not having to turn on the cabin heat and triggering the ICE, but that doesn’t solve the window defrosting issue.
    I was thinking today as we got the first of our seasonal rains here around the Sacramento area, and the ICE kicking in while defrosting the windows, it would be nice to have another non-ICE solution for this. I’m not sure if the technology yet exists, but if there was a defrosting system on the front and side windows similar to the defrosting grid of the rear windows, but invisible to the eye, this might do the trick.
    Any ideas out there?
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    A block heater will work but not for long term once unplugged.
  3. iplug
    iplug Senior Member
    2,455
    1,703
    Rocklin, CA
    I just saw another post on a separate thread that went up the same time as mine. It noted using the AC to vent to the windshield. I did try this before, but got mixed results - sometimes the ICE was triggered. I wonder if the ICE triggers in this scenario when the cabin temperature is below the set preferred temperature and AC and warming therefore have to come on thus having the warming demand triggering the ICE. I suppose the cabin temperature preference could be set very low, but this would make for a pretty chilly cabin.
  4. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    The ICE will start if you turn on the cabin fan with the climate control temperature set higher than the outside temperature. You have to turn the temp way down to keep the gas engine off.
  5. bisco
    49,397
    i wonder if the 100w 12v heater placed on thedash facing the windshield would do anything?
  6. John H
    John H Senior Member
    2,208
    558
    I think running the electric AC to put dry air onto the windshield is the path to follow for removing fog and condensation. Just make sure that the thermostat is set low enough to not call for heat.
    Using the electric seats seems to be effective as well for passenger comfort.
    An add on12v electric space heater for the cabin is somewhat limited.
  7. mrbigh
    3,686
    699
    Long Island, NY
    Yes, expend valuable electric power hence shorter EV range............
    NortTexSalv04Prius likes this.
  8. John H
    2,208
    558
    I think these are only strategies aimed at trips that are shorter than the EV range. If you are travelling a longer distance than the EV range, firing up the ICE is probably the most effective option.
  9. bisco
    49,397
    true, but if you can still manage the whole trip in ev, no harm no foul.(y)
  10. SJ PiP
    SJ PiP Member
    190
    35
    anyone know how "expensive" in EV miles the seat heaters typically run? can live without them in cali but i'd imagine pretty useful back east.
  11. iplug
    iplug Senior Member
    2,455
    1,703
    Rocklin, CA
    I found an article about transparent coated glass with heating elements that could be applied to windows. Would be nice if Toyota incorporated something like this in the next gen PIP:
    Coated Glass for Transparent Heating Elements :: NASA Tech Briefs
    (full article isn't much longer, but available with free registration)
  12. Rebound
    3,964
    2,613
    Portland, OR
    I think the method I described in the other thread, of using the AC, rear defrost and seat heaters, is about as good as it gets. It will do the job in moderate weather. But if your car is kept outdoors and it's really cold, in the 30's, you really have no choice but to let the engine warm up. I don't deal with snow, but in the coldest part of winter here, we get a thick layer of frost.
    Time will tell if I can use the windshield fluid to melt it and the AC to keep the frost off. I'd rather sell my house and get one with a garage :)
    From this morning's experience, though, using the AC/rear defrost/seat heater works, and it works faster than waiting for the engine to warm up. You just have to be sure that you set the cabin temperature to LOW, (the lowest temperature), or else the engine will start.
  13. This morning was a little cooler in Sacto with our first rain. My windows stayed clear, didn't bother with heater. I ended up with 30 one min. Bars of 100mpg, coming back I must have goosed the go-pedal a bit and got a few short bars, but still took the long term mpg from 82 mpg to 88 mpg. Our winters are relatively warm, so we do not need gloves to drive. I would be interested, but not envious of any Prii commuters that must travel 30 min + in 10 to 20 degrees F .
  14. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I will wear a heavy winter coat. :D
  15. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    50mpg doesn't do you much good if you can't see. Running the defrosters in the wet & chilly AM is unavoidable.
    The heated seat does not cause the ICE to spin up so it and a coat is a "better" choice than running the heater.
  16. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    plus, I got a sponge like thingy on a long rod like device to wipe any condensation off the windshield.:D
  17. A squeegee also works, sponge like thingys on long rods cannot always be guaranteed.
  18. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    sorry, not a sponge, but a little "towel" wrapped around a plastic rectangular plate with a handle on it. Squeegee works too:D
  19. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    mrbigh likes this.
  20. TY Kitty, that looks like a good idea.
