Identify This Component?
Discussion in 'Gen 3 Prius Technical Discussion' started by chris14020, Jan 28, 2018.
  1. chris14020
    chris14020 Junior Member
    29
    26
    Buffalo
    I damaged the plug on this part while reinstalling the engine. Does anyone know what this part is called? This is obviously just a stock photo, but it is the black plastic component on the transmission, lower right. Thanks!
  2. High Mileage
    High Mileage Active Member
    136
    238
    2018 Prius Prime
    That is the transmission shift actuator. Its purpose is to engage the parking pawl of the transaxle to lock the vehicle from moving.
  3. chris14020
    29
    26
    Buffalo
    Ohoo, fun. Thank you. Is it as simple to change as it looks?
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    This is a Gen 2 but funtionally the same
  5. padroo
    padroo Senior Member
    2,763
    2,253
    Check out the comments at the 16 minute mark in this video. This is a gen 3 though.
  6. ChapmanF
    18,916
    You may find the mounting bolts hard to remove because of an anti-theft design—this device is the antitheft provision on your car, as you'll notice the steering column does not lock as they used to on most cars, and those bolts with caps are what's supposed to slow somebody down from just removing the actuator and rolling the car away. (In Gen 2, they accomplished the same thing without special bolts, just by situating the actuator in a barely-reachable place on the other side of the tranny.)
    I've never tried, so I don't know how creative you have to get with those bolts and caps to remove them. In case you end up getting extra creative....
    Or you could put it back on with plain bolts of the right size and thread from the hardware store, but that would be defeating one of the purposes.
    -Chap
    Edit: I just watched the 16-minute stuff in the video above, and saw that he showed the security bolts in detail, though he never quite really guessed what they're there for....
    #7 ChapmanF, Jan 28, 2018
  7. padroo
    2,763
    2,253
    Starting at the 24 minute mark he show the details of transmission shift actuator but doesn't remove it.
    There is a fairly good close up of the special security bolts used to keep people from stealing your Prius.
    http://www.youtube.com/watch?v=-dHeRJdrnI8
    Looks like a hex security bit should remove it but what size.
    #8 padroo, Jan 28, 2018
