IDENTIFYING TRACTION BATTERY SERIAL NUMBERS
Discussion in 'Gen 2 Prius Technical Discussion' started by Dxta, Jun 9, 2017.
  1. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Please do battery modules have serial numbers, and how do I lo ate the numbers?
    Appreciate your replies.
    Thanks
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    JC should come along here soon........ standby.
  3. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Alright edthefox5. Would be standing by
  4. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    Raytheeagle likes this.
  5. JC91006
    16,939
    8,647
    I don't have the printout on the serial number identification but basically you look at the 4th letter in the serial number. 1999 was letter A. 2000 letter B....and so forth. Gen 2 started in 2004 with a letter F.
  6. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    terramir, ITBland, SFO and 2 others like this.
  7. 2005pluginhybrid
    51
    25
    vancouver
    I have 2 bad cells in my pack from a 2005 prius
    starting with 092G Feb 9,2005
    I have replacement cells that look like they are out of a 2008
    starting with 13YJ Nov13 2008.
    Should I be concerned about the date difference, or just check capacity and if they look close, it should be ok
  8. JC91006
    16,939
    8,647
    The dating doesn't really matter that much. But you should recondition all your modules afterwards. If you are only going to do a module swap.....then the repair won't last as long as many of the modules will be out of balance.
    strawbrad likes this.
  9. 2005pluginhybrid
    51
    25
    vancouver
    Thanks
    I am in the process of testing and conditioning the pack on another thread
    https://priuschat.com/posts/2676238/
    but when I looked up the dates, I was a bit concerned. I will see how they compare. I am hoping they will be close
  10. JC91006
    16,939
    8,647
    There are many factors in the way a battery module will perform. It's not just the date. We've seen packs here with modules from 2003-2012....all in the same pack and the pack lasted an amazing 18 months.
