If a Prius drifts
Discussion in 'Gen 3 Prius Main Forum' started by Obxmush, Oct 5, 2012.
  1. Obxmush
    Obxmush Member
    60
    39
    Outer Banks NC
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I may be wrong, but I thought you had to have driven rear wheels to drift. RWD or AWD
  3. Obxmush
    Obxmush Member
    60
    39
    Outer Banks NC
    You do, I scalped it from a friends post on Facebook. If you look closely you can see the gran turismo logo in the upper right corner
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Whew, I thought I understood the Physics of drifting.
  5. Obxmush
    Obxmush Member
    60
    39
    Outer Banks NC
    Yeah, you get the back end of a Prius out its called a slide.
  6. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    The VSC with no OFF option would put a stop to a slide pretty quickly.
  7. PriusCamper
    PriusCamper Senior Member
    13,463
    5,431
    Pacific Northwest, USA
    Correct me if I'm wrong but from my high school days I learned that while you could obviously drift easier with rear-wheel or all wheel drive. A wee bit of drifting is possible in front-wheel drive cars... Catch is once your rear end slides out you can't counter steer it back into place unless you also accelerate, or pull the rear wheels back in line at the same time... it takes some fancy clutch work too once the the front wheels start drifting. It's a wonder I didn't get killed during unsupervised auto shop class test drives......
    It'd be probably quite challenging to do in a Prius with skid control, but race car drivers can do amazing things!
  8. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    692
    151
    Seattle, WA
    I've drifted mine around a wet freeway onramp - FUN
    PriusCamper likes this.
  9. cossie1600
    cossie1600 Active Member
    903
    94
    CT
    I ran two slicks up front at an autox once, the stability control wouldn't let me do too much sliding. Too bad there is no VSC button off
  10. PriusCamper
    13,463
    5,431
    Anyone know how to hack a way to turn traction control off without harming the drivetrain?
    It couldn't be that hard, could it?
  11. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Its not a hack, you just put it into service mode. The same mode used for emmisions testing. The engine will constantly run, but stability control and traction control are completely disabled. The warning is if while slipping it then gains traction, there is the potential for a surge of power in the PSD to compensate which can be bad for the components over time.
  12. PriusCamper
    13,463
    5,431
    Makes me wonder how they manage the Prius race car transmissions...
  13. cossie1600
    903
    94
    CT
    I have a RXh, that car has the ability to turn off the traction control. Since they have the same basic system, how come I can spin tires in the RXh?
