If I was Lead Designer for the Prius, I would.....
Discussion in 'Gen 2 Prius Main Forum' started by j24816, May 24, 2006.
  1. AnOldHouse
    AnOldHouse Member
    677
    Middlesex County, Connecticut
    <div class='quotetop'>QUOTE(skruse @ May 25 2006, 11:26 AM) [snapback]260892[/snapback]</div>
    Top of my list!
  2. JEBster
    JEBster New Member
    MFD to display MPG based on miles driven, not time.
  3. ServoScanMan
    ServoScanMan Member
    262
    Lorena, TX
    I would allow the user to modify the program for controlling when the ICE turns on. I would display (or at least make selectable) more sensors and data. I would have GPS terrain anticipator (forward thinking) logic that would optimize the battery charge state because in knows about the elevation changes and speed changes in the road before you get there. I would have external (front, side, rear) air bladders automatically inflate before a crash. And of course, more electrical storage with plug-in option.
    Tideland,
    Your logo moves on me. If you stare at the text in your post the blue background shrinks. If you stare at your logo the blue background shrinks. Weird...
  4. darelldd
    6,059
    389
    Northern CA
    1. Get rid of the gas engine, the exhaust, the fuel system, the planetary transmission.
    2. Add lots of Li-ion batteries and V2G charger.
    3. Make it look like the next generation will look.
    4. Adjustable lumbar
    5. heated seats
    6. More power outlets
    7. Hand brake instead of foot
    8. Incorporated roof-rack anchors
    9. Good-looking wheels
    10. LED interior lighting
    11. LED signal lighting
    12. Projector HID
    13. Real FOG lights
    14. Solar assis, with auto-ventilation when parked
    15. Most of what the others have said.
  5. j24816
    j24816 New Member
    141
    Los Angeles
    <div class='quotetop'>QUOTE(skruse @ May 25 2006, 08:26 AM) [snapback]260892[/snapback]</div>
    Actually I think the climate control system can do everything except stand on its head and paint the Mona Lisa, but
    1) The manual is useless,
    2) Design is not intuitive,
    3) Adjusting while driving is dangerous, and
    4) It assumes a particular a particular style of usage (auto) and does not adapt easily to other styles (manual/passive). #4 is a common trap GUI developers fall into.
    To get air flow, try this (which another PriusChat poster was considerate enough to share):
    1) Push Climate button.
    2) Turn on Auto
    3) Push temperature button umpteen times to get to desired temperature (warm air flow or cool air flow).
    4) Push off.
    You should now get your desired air flow. If anyone has an improvement on this, please (please, please) share.
    Compare this to adjustments required in a 'normal' configuration.
    1) Slide/turn temperature control to desired position.
    The lack of really basic usability engineering is quite a surprise on a Toyota product.
  6. drummoros
    drummoros New Member
    37
    Kingston, Ontario, CANADA
    Here are the top of my list:
    the ability to pop open the hatchback from inside the car (I know its open but the grocery clerk can't find the way to open it!!)
    More ability to control the phone and navigation by driver or passenger when moving
    a 'legal' EV switch in the North American vehicle
    A choice of leather upholstery in Canada
    the ability to get a darker interior than bisque in Canada with Barcelona Red --- the light colour is a mistake!!
  7. danoday
    danoday Member
    206
    Incline Village, Nevada
    Wow.
    Shakers. For starters, lots of people own Prii, but have no idea how to drive them for maximum efficiency. Here's what I'd do: add shakers to the steering wheel. When you drive inefficiently, the steering wheel would 'vibrate' a bit to tell you. The more inefficiently you drive, the more it vibrates the wheel. As you drive, and slip into a bad driving habit/mode, the wheel gently nudges you back into a more efficient mode. The Prius would need to be programmed to recognize bad driving habits... this might be the biggest challenge, as you don't want the car telling you to drive 45mph when you really want to go 70. Yes, we could do something similar by watching one of the info screens, but the vibrate way would allow you to do it almost subconsiously. The Prius would essentially 'teach' it's owner how to drive by modifying the owner's driving habits and style. Of course, you'd need to be able to disable this function if you really weren't interested in learning. Wheel shakers have been around for a long time... they're used in some aircraft to alert the pilots to certain things, and they're also used in video games to provide feedback to players.
    Efficiency-enabled navigation system. We're already looking at the shortest or fastest route information... how about tying in topographic information and allowing the Prius to calculate the most fuel efficient route? I'm sure the Prius can calculate how much energy can be derived from going downhill, and if it knows where the downhill parts of your route are, it could plan much better.
    Solar panels. Yeah, they might not be that efficient, but they'd be cool. There is a lot of space on top of the car... some flexible solar panels would look really good there. Isn't there a photo-reactive paint in development somewhere?
    Built-in AC inverter. Give us an outlet in the car for AC items. I usually carry a portable inverter for my laptop, and it runs fine off the Prius. In fact, last year, I used the Prius to power my laptop and a computerized telescope. About once an hour, the Prius ICE would turn on, charge for five minutes, and then shut off.
    Plug-in. This would only work with improved batteries, but give us the option of plugging in our Prii at night.
    Scrubbers. Saab or Volvo did a prototype a few years ago of a system that used solar power to scrub pollutants (CO2?) from the air around it. Since the car had a solar panel, it would detect when it had excess battery power and run the scrubbers even when the car was off and parked. It essentially became a less-than-zero emission vehicle. Yes, not exactly necessary, but really cool. Can you imagine parking next to a Hummer, and 'taking care' of it's emissions?
    Built in MP3 player with a hard drive. C'Mon Toyota, make a relationship with Apple. Add WiFi so I can update all my podcasts while parked in the garage!
    Functionality lockouts. Get rid of them. If I want to dial the phone from the screen, let me... it's my car, and I promise not to sue you. At least create a permanent way to disable the lockouts
    Plural. Put the plural of Prius somewhere in the owner's manual. End the argument once and for all. Personally, I'm voting for "Prii".
    Dan
  8. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(Prianista @ May 24 2006, 09:04 PM) [snapback]260749[/snapback]</div>
    I think a manual lever by the driver would be better. That way if there's no power you don't have to crawl into the trunk to get to the battery.
  9. goodsam
    goodsam New Member
    38
    In addition to those suggestions already made, I would change the arm rest and console material...I'm afraid to touch it unless I'm straight out of the shower.
  10. seasidetraveler
    662
    CA
    <div class='quotetop'>QUOTE(TonyPSchaefer @ May 25 2006, 12:00 AM) [snapback]260711[/snapback]</div>
    I agree! When I first bought mine, I found lots of things that I would change, because I wasn't used to it- but now that I have had it over a year, there isn't a whole lot I would change. I am not an engineer, so I can't get into the computer crap- but funtionally it seems to do it's job just fine for me- I do hate battling the sun- all visors should have the little extenders IMO
  11. Acelin
    Acelin Junior Member
    51
    Everett, Washington
    <div class='quotetop'>QUOTE(Sam-I-Am @ May 24 2006, 10:10 PM) [snapback]260768[/snapback]</div>
    :lol:
    Me: ...and I'd like that with the Placebo Shifter Package.
    Dealer: Certainly sir, would you care for the optional Vroom-Vroom sound effects?
    Me: No, I can do that myself.
  12. Kirkman
    Kirkman New Member
    What changes would I make to this fantastic vehicle? Increase the size of the nickel metal hydride batterys, (the lithium batterys are still not proven for hybrid's constant charging and discharging) make the passeger and driver seats adjustable (up and down) ......Give the option to plug in and charge the batterys, And that's about it. Great vehicle! I've had my 2006 for 2 weeks now and its great!!
  13. Salsawonder
    Salsawonder New Member
    1,897
    47
    La Mesa California
    The Hatch thing that also comes to mind is for it to be auto-opening with a push button on the fob.
  14. Potential Buyer
    Potential Buyer New Member
    287
    1) Forward visibility. Maybe it's because the seat has no height adjustment and I'm 5'6, but the forward visibility seems really bad. My new Camry Hybrid seems better in this respect, but probably just because of the seat height adjustment it has.
    2) Cheap interior. The interior is poorly laid out, the dashboard gauges are weirdly offset and are cheap, the console is too hard for the driver to see when driving, and it's completely dark at night except the console which is very bright. Fortunately the Camry Hybrid has none of these problems except the last one -- it too is very dark, with few switches being lit, except for the center console area which is very bright. Both the darkness and the single bright area are bad. For example, the controls to lock/unlock the doors, or open the windows, or adjust the side mirrors, are all completely unlit and thus invisible at night, in the Camry and AFAIR in the Prius too.
    3) Flexible fuel bladder. Of course the Camry has a normal 17.2-gallon gas tank which gives it phenomenal range even while getting 10 mpg less than a Prius.
    4) So bland and boring to drive. Fortunately the Camry is more enjoyable.
    So there's alot I don't like about the Prius, but the Camry suffers from almost none of them. Of course it is heavy and large, a problem the Prius does not have.
  15. hycamguy07
    hycamguy07 New Member
    2,707
    Central Florida
    Gathering all the posts just convert the camery into a hatch back & get a GEM on a pull behind trailer for ddarrll ;) :)
  16. finally_got_one
    finally_got_one New Member
    151
    Orange County, California
    1) Add optional turn signals to side mirrors.
    2) Better battery system able to take the car at least 20 miles on battery alone.
    3) Optional plugin capability.
    4) Optional EV switch
    5) Adjustable Lumbar supports in front seats
    6) Move backup beep to outside the car
  17. Subversive
    Subversive New Member
    251
    Things that come to mind for me are:
    Larger fuel bladder.
    E/V option.
    Slightly brighter lit buttons on the steering wheel.
    More hatchback door options (like remote spring-open).
    A third choice, a simulated duel Tachometer display, to the Energy and Consumption choices.
    And of course, plug-in Lithium battery (and upgrade option).
    Personally, I like the seats fine--I find them comfortable at 6'0" tall with long torso and 400+ lbs.
    And I absolutely hate the "shakers" idea, unless it can be easily disabled.
  18. hycamguy07
    2,707
    Central Florida
    <div class='quotetop'>QUOTE(finally_got_one @ May 25 2006, 07:59 PM) [snapback]261094[/snapback]</div>
    7) built in keg tap for ice cold beer at tailgate parties.
  19. momfortheenvironment
    146
    Southern New Hampshire
    don't have one yet, but the whiplash safety on the seats and lack of lumbar adjustable support and the ability to raise the seat even manually would helpme, I'm short and have a neck injury.
  20. hycamguy07
    2,707
    Central Florida
    <div class='quotetop'>QUOTE(momfortheenvironment @ May 25 2006, 10:27 PM) [snapback]261151[/snapback]</div>
    Ok they make the Ronco Butt-Pillow to lift you.
    Fire/Rescue C-Collar for the neck injury & a Lumbar pillow for your back.... ;) :D :)
