If only there were a Corolla Hybrid Chat
Discussion in 'Newbie Forum' started by richard schumacher, Apr 14, 2026.
  1. richard schumacher
    7,683
    1,066
    United States
    After 22 years I've replaced my Gen II Prius with a 2026 Corolla hybrid. Gen 5 Prius visibility was just too limited; the interior felt like a capsule. So far, so good, but I miss having a reliable comprehensive source of info and discussion, as is PriusChat. For example:
    - Toyota specifies 0W-16 oil in the US and 0W-20 in Europe. Plausible rumor has it that this is for better EPA fuel economy in the US and longer engine life in Europe. I don't dare risk the Toyota warranty by using the heavier oil.
    - What is the maximum amperage that can safely be drawn from the 12V system by an aftermarket accessory? Gen II Prius was rated for 100A, sufficient to power a 1kW AC inverter. I've no clue yet what is safe in the Corolla.
    Gen II Prius things I miss: temporary spare tire and rear window washer & wiper.
    Things I won't miss include the fuel tank bladder, the brake accumulator, the belt-driven engine coolant pump, and the coolant thermos and associated transfer pump and valves.
    #1 richard schumacher, Apr 14, 2026
  2. BiomedO1
    BiomedO1 Senior Member
    4,534
    2,386
    Left Coast
    Double check your oil fill cap or OP manual; I believe it's down to 0w8 now - at least the regular Corolla had been down to that for a couple of years now, I believe.
    richard schumacher likes this.
    52,790
    congrats Richard! we're considering the corolla cross to replace our hycam in the future.
    pics, or it didn't happen :cool: all the best!
  4. richard schumacher
    7,683
    1,066
    United States
    Thanks! And the best to you as well. (Now how do I upload these glass plates...)
    bisco and Mendel Leisk like this.
  5. richard schumacher
    7,683
    1,066
    United States
    True, for the non-hybrid. For the hybrid the manual and the oil fill cap both read "SAE 0W-16". Good to check :_>
    #5 richard schumacher, Apr 14, 2026
    BiomedO1 likes this.
  6. Winston Smith
    Winston Smith Active Member
    456
    328
    OH
    2024 Prius
    LE AWD-e
    I came from a Corolla hatch to the current Prius.
    The Current Corolla sedan is shorter, is easier to get in and out of, has a better back seat, a pretty big trunk, and simple, intuitive controls. It is zero percent weird. Weird is the calling card of the Prius.
    richard schumacher and bisco like this.
  7. VelvetFoot
    VelvetFoot Senior Member
    1,407
    545
    New York State
    2026 Prius
    Sedans suck.
  8. richard schumacher
    7,683
    1,066
    United States
    Prodigyplace likes this.
  9. ColoradoBoo
    ColoradoBoo Senior Member
    1,340
    964
    Monument, Colorado USA
    Congrats on the Corolla Hybrid...it's a great car, I like my wife's 2024 more than I like my 2021 Prius! She has a 2024 Corolla Hybrid SE AWD model in the blue (Celestite) Since maintenance is so easy, I'll just do both our cars on the same day for oil/oil filter change and tire rotation. (Every 6-months or 5,000 miles, whichever comes first.)
    Yes, it takes 0W-16 oil and it's fine....just cut in half every Toyota Maintenance recommendation if you want to keep the car for the long-term. The Corolla Hybrid and Gen 4 Prius are almost identical, mechanically. (I'm not familiar with the Gen 5 Prius but would assume it's, also, similar.) Same oil filter, air filter, even same charcoal cabin filter. I like Mobile One Advanced fuel economy but switch our older (10+ years) cars to Valvoline Restore and Protect.
    The Corolla did not come with a spare tire (AWD uses up the space in the trunk) so I bought a wheel/tire and store it in the trunk....no way I'm waiting 2-3 hours on the side of the road for help when I get a flat.
  10. richard schumacher
    7,683
    1,066
    United States
    I preferred a hatchback, and being a bit shorter overall one would have been a better fit in our garage, but the Corolla doesn't now have a hybrid version. Dang it.
    Following my rule of buying a new car every 20 +/- 2 years the next one will be an EV.
  11. richard schumacher
    7,683
    1,066
    United States
    VelvetFoot and bisco like this.
  12. richard schumacher
    7,683
    1,066
    United States
    So far as I've found, the generally preferred solution for aftermarket spares and kit is ModernSpare/ValueSpare (they say they're "sister companies", whatever that means legally).
    Engineered Model-Specific Compact Spare Tire Kits | Modern Spare
    Moments ago they emailed saying that their offering for the 2025 Corolla is compatible with the 2026 hybrid, and that they will update their website to show it explicitly in the pulldown selection menu.
    bisco and ColoradoBoo like this.
  13. Prodigyplace
    12,710
    11,848
    Central Virginia
    Toyota lists the Corolla Hybrid trims on the generic Corolla page.
  14. ColoradoBoo
    1,340
    964
    Since I'm cheap, I didn't dish out the big bucks for the little donut spare, got a cheap steel wheel and tire from Discount Tire for about $100 less...not sure why those donuts are so expensive. (If you've ever used one, you know they are only good for about 2-3 uses....one if you have a long drive....and then are just about bald.)
  15. Prodigyplace
    12,710
    11,848
    Central Virginia
    The 2017 Prius Two was designed to accept a full sized spare anyway because they sold it that way in Israel. i had a 2017 Prius Two until it was totalled in 2024 by a 4Runner.
    ColoradoBoo likes this.
  16. VelvetFoot
    1,407
    545
    New York State
    2026 Prius
    I've got a new donut for free if anyone wants it.
    Upstate NY though.
  17. richard schumacher
    7,683
    1,066
    United States
    D'ohh..!! I completely forgot about the Corolla Cross. Thanks.
  18. richard schumacher
    7,683
    1,066
    United States
    Two sub-optimal things:
    - No way to display the backup camera view on demand. It displays only when in R. [According to the dealer this can be done in only a few high-end offerings, such as Tundra Limited and Sequoia Platinum]
    - Rear seat headrests cannot be removed. The passenger side headrest partly obscures the rear view. The only workaround is to drop down that side of the split seat.
    #18 richard schumacher, Apr 23, 2026
  19. richard schumacher
    7,683
    1,066
    United States
    Annoyingly, the Toyota Parts Center Online suggests otherwise:
    0W16 Motor Oil - Genuine Toyota Motor Oil - 6 Quart Case
    The Toyota Engagement people explained that the Parts Center Online is not always correct [!]; the owner's manual and oil cap are to be relied upon.
