If the price of diesel was lower than gasoline's would you still buy a Prius?
Discussion in 'Gen 3 Prius Main Forum' started by vahrn, Oct 31, 2009.
  1. Yes
    84 vote(s)
    82.4%
  2. No
    18 vote(s)
    17.6%
  1. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  2. DickPhillips
    DickPhillips Member
    89
    58
    Mount Vernon, WA
    We have a VW diesel New Beetle that has given us no problems. It is an automatic by choice (my wife's car) so its mileage isn't as great as it could be but it still gives consistently about 48mpg on the road. Our overall average driving is more like 30 - 32mpg with most miles at city speeds. During the first part of this year diesel fuel prices were lower than gasoline for the first time in quite awhile but that has now turned around and they are higher. It is easy to find fueling stations for the car in our area so we don't have to go to truck stops.
    We just bought a new Gen III Prius rather than a second VW TDI. I have been very interested in getting an electric vehicle but at this point there are none that are affordable and will do what we want, so the Prius is sort of a compromise. It pretty much does what I want a car to do and also is fun to drive. And its mileage in town is a lot better than that of the VW.
    I guess I'll go cast a "yes" vote.
  3. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    Right now diesel is about 14 cents/gallon higher here, about 6% more than gasoline. That's been fairly normal in recent years although rarely diesel is a little less expensive and at times it has been WAY more expensive.
    If/when the economy recovers the long haul truckers and other commercial/industrial transportation needs will soon drive up the relative cost of diesel again. It is more sensitive to economic conditions than gasoline consumption.
    If the U.S. were to convert any significant portion of the personal vehicle fleet to diesel, then the relative pricing of diesel would move even higher over the long haul. Such a switch in demand would also depress gasoline prices further moving the ratio in gasoline's favor. That sort of imbalance could be expected to last a decade. Refining projects of that scale take time and tend to lag, awaiting market confirmation before getting underway. The pace can be glacial.
    On the other hand, I suspect we will be seeing continued reduction in gasoline demand with or without growth of diesel demand. So from a refining perspective, gasoline appears to be a better longterm bet for the consumer.
  4. patsparks
    10,664
    567
    Adelaide South Australia
  5. vahrn
    vahrn New Member
    66
    Parma, Italy
    It's a 1.6 diesel on a small car. It's not a fair comparison. The Prius is roomier, quicker and less polluting. Clean diesel are a myth, there is no way particulate can be eliminated, when the particulate filter is regenerated the result is UFP (ultrafine particulate), way more dangerous than standard particulate
    Interesting reading about the subject: http://www.northeastdiesel.org/pdf/UFPwhitePaper20070205.pdf
  6. abosman
    abosman Junior Member
    Farmington Hills, MI
    My friend at work has a Volkswagen Beetle, which only gets 44mpg diesel. My 2012 Prius III during break in period 3 tank full is avg. between 49.6 and 54 mpg combined driving, enough said.
  7. Indyking
    Indyking Happy Hyundai owner...
    1,280
    I don't know... Indy, Chicago, Madison (WI)... it
    My vote would have been YES a couple of days ago but with the rattle issues I'm getting in my Prius, now, I would say, NO.
    I considered a Jetta TDI instead of the Prius because my commute is long and mostly HWY. I test drove both cars many times and I found that Prius gets better MPG in the city or hwy but the gap is very narrow in the hwy. Depending on cruising speed, the Jetta TDI can deliver better hwy mileage than the Prius (the Prius tend to get disproportionably strong MPG hits after 70 MPH). I would likely not be frustrated right now with rattle noises if I got the TDI instead but since I intend to drive this car 40K/year up to 4 years, the Jetta would potentially give me a lot more maintenance problems down in the road.
    So, if a TDI from a more reliable source other than VW was available… No.
  8. fuzzy1
    10,429
    Actually no, not enough said. Differences in driving style can easily exceed that spread.
    I'm not disagreeing with your conclusion, only with the reasoning behind it.
  9. phunkopathic
    phunkopathic New Member
    26
    Columbia, Mo
    Tough call... I love the diesel engine and it's longevity. The old Mercedes diesels are well known for hitting a million miles. How about a diesel hybrid? THAT would definitely be one that I would ponder.
  10. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    This is a personal opinion poll. He was giving his very own opinion. It was enough said to explain HIS opinion on it.
    Not every posting here should have to say YMMV - we all know that.
  11. seftonm
    seftonm Member
    408
    78
    Winnipeg, MB
    Hi Shawn, it probably depends on where the consumer is located. For me, it's kind of the inverse of your situation. On rare occasions, diesel is a little more expensive but it's generally less expensive and sometimes way less expensive. Diesel has been more expensive for only about 5 months out of the 5 years that I have owned my car. That was winter 2006 IIRC, which was the first winter with ULSD. I'm not sure if that was the cause, however. Gasoline is probably the better longterm bet for most consumers, however I would place my bets on diesel if I'm the consumer.
  12. GoSkins
    GoSkins Member
    132
    Frederick, Maryland
    Oh, now you done it! It is really going to throw things off. Suggest you have a friend or spouse come on and vote "yes". That will wash out your "no" vote. Then have another friend come on and vote "yes". That should set things straight in your mind that the right amount of "yes" votes were cast. You'll be all right with the world then----and the survey.:cheer2:
  13. GreenWithEnvy
    GreenWithEnvy New Member
    81
    SE Wisconsin
    With my current situation (mostly city/ slow commute highway driving) the Prius was the right choice. Please continue to tell me all the bad things about diesel though...I still lust after the Audi A3 TDI and they are not even here yet!
  14. Rhino
    Rhino New Member
    460
    U.S.A.
    Even though a Prius would be "my car", I expect that my daughter/son might have to drive it sometime - emergency. I can't imagine forcing anyone to use diesel if they are not already familiar with it.
    There are a lot more 24 hour gas stations than diesel stations.
    There is just all these explaining to do. Don't use the regular pump, make sure they sell diesel. If you can't find it go to a more truck stop kind of place.
    I want a car I can hand off to anybody in a jiffy. And if I were to get a personal car for myself, just for fun, I would get something preppier than a diesel.
    With a gas car, I can just say, "here son/daughter, I know your car broke down, why don't you go camping with my car." Instead of "be sure you fill up before you reach the campground, ask the camp people, before the office closes, where the nearest diesel station is. Make sure they know the difference between a gas station and a gas station that sells diesel."
  15. Indyking
    1,280
    Now that you mentioned it... I was really excited about the new A3 TDI but I needed a FE car quickly back in June, so I got the Prius. As much as I like driving my Prius, all the rattles I'm hearing on it everyday and the cheap interior feeling caused by it has caused me to wonder if I should have waited for the A3 TDI. Now it's too late. The basic Audi A3 is not that much more expensive than what I paid for my Prius, which aggravates my frustration a little bit. Actually the base A3 TDI is just a tad more expensive than a Prius V with NAV but without AT package, believe or not. The A3 TDI is rated 42 MPG for hwy, but EPA hwy estimates for TDI engines are typically underestimate. I drive 98% hwy and I bet I could do better than EPA.
    I have driven many luxury cars before, not mine per se, but let's just say a very close friend of mine can afford changing luxury cars frequently... and nothing feels like an Audi in my opinion...
    Beautiful...
  16. Geistemite
    Geistemite Junior Member
    31
    Menifee, CA
    My other car(truck) is a Diesel. Love it for what I need it for. It gets over 20mpg on the highway, when not pulling my trailer. Not too bad for 8000+ lbs.
  17. Sealawyer
    Sealawyer New Member
    32
    Fort Lauderdale, FL
    Let's put it this way:
    If Toyota made a diesel, I might consider one...
    Since, at this time, the only non-truck diesel's being offered in the U.S are VW and the newly introduced Audi (which in my estimation is just an upscale VW), I'd have to say no...
    Moreover, in Florida hybrids can get stickers to travel with one person in the HOV lanes. Diesel drivers do not get this option.
  18. vahrn
    vahrn New Member
    66
    Parma, Italy
    Audis are rebadged VWs with some good leather and super expensive options. They call themselves sporty and yet all they have are some fake AWD cars (front + rear if looses traction) or FWD, no RWD which is the only sporty configuration. Every model has way too many engine options: you can't have a chassis that can cope with 90 bhp engines as well as 270 bhp engines. And I don't like compromises: if a want a sports car I buy a sports car, not a car which pretends to be everything and ends up to be nothing. Given the price they ask for a rebadged Golf I'd take a BMW over an Audi any day of the week. RWD, proper engines, near to perfect weight distribution, great road feeling. In a word: substance.
  19. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    In many vehicles Diesels make more sense. For Instance My C3500 Duramax will get 18 MPG. Same truck with a gas motor get's about 10 or so. The Diesel option was $5,000 more in 01. When Diesel was cheaper than gas, you could drive a Diesel truck for about half of the fuel cost of a gas truck.
    How many gas 18 wheelers, trains and big boats etc. have you seen?
    The bigger the vehicle, the more sense Diesel makes
  20. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I won't argue with that. My next truck will definately be a diesel. If they every get the small cube (4.5L) diesels into 1/2 ton trucks I'm so there. For my work I simply do not need a 7,000lb 3/4 or 1 ton truck.
