If they want it...
Discussion in 'Fred's House of Pancakes' started by frodoz737, Jan 12, 2014.
  1. frodoz737
    frodoz737 Top Wrench
    4,807
    2,561
    33
  2. bwilson4web
    16,537
    There are few things more sensitive than our drone technology, especially a stealth drone:
    Source: IRAN AIRS FOOTAGE OF THE CAPTURED DRONE - Business Insider
    If someone had a nuclear device and wanted to deliver it, a stealth drone would be an ideal platform. Unlike a rocket, it can't be detected by satellite systems. A difficult radar target, again, all but impossible to detect. At slow speeds, easily GPS guided.
    The current hypothesis is the Iranians spoofed the GPS signals to get the drone to fly to the capture point.
  3. frodoz737
    4,807
    2,561
    33
    o_O Perhaps the title of this post should have been more descriptive, instead of just trying to draw attention. I was giving PC owners a friendly heads up on how easy it is to steal a Prius, not engage discussion regarding international weaponry.
  4. bwilson4web
    16,537
    I'm not trying to be difficult but why not a tow truck?
    The Iranian trick was more impressive. It was done without touching the vehicle until it was captured. The Prius and Escape hacks were more direct with removing of the dash and electrical connections to the vehicle electronics.
    Now if the Prius hackers do that to a second, stock Prius they are not allowed to touch, I would be impressed.
    ftl likes this.
  5. frodoz737
    4,807
    2,561
    33
    Noted by mx.
  6. kenmce
    kenmce High Voltage Member
    1,552
    525
    NY
    I must respectfully disagree. He has a physical connection into the CANBUS. He can't stand outside a random car and tell it to do things. He would still need a tow truck to steal a Prius, same as anyone else.
  7. frodoz737
    4,807
    2,561
    33
    Noted by mx.
  8. kenmce
    1,552
    525
    NY
    What's MX?
  9. frodoz737
    4,807
    2,561
    33
    Noted by Maintenance.
  10. kenmce
    1,552
    525
    NY
    Aviation shorthand?
  11. frodoz737
    4,807
    2,561
    33
  12. tochatihu
    tochatihu Senior Member
    9,987
    3,854
    Kunming Yunnan China
    2001 Prius
    CAN bus hacking puts all modern cars at risk, but these two examples probably more than most. I think it is very appropriate for Valasek and Miller to give the heads up. But I think they could have just as effective (at their stated goal) by anonymizing things just a bit.
    I remember many discussions here and Yahoo Prius technical stuff concerning network hacking that was not entirely different. The other old codgers do as well.
    Seems to me an important issue is what can be done over bluetooth or other wireless portals. That, at least, needs a firewall. With a physical connection to the bus,you could add layers of security, at the expense of making legitimate vehicle maintenance more difficult to perform.
    Bob, I agree that a large drone could deliver something like a 400 kg W88. Perhaps not a much heavier fission package that rookies might be able to put together. There are many smaller non-fission devices that a rookie could make that I sure don't want dropped on my head.
    I suppose that GPS spoofing will change in the future when there are 4 parallel networks of geolocating satellites. That's where we are headed, right? India is out of the game?
    Then one would be continuously checking for consensus.
  13. kenmce
    1,552
    525
    NY
    If you're concerned about weight, just put it in one of those intermodal land/sea containers and have a semi deliver it. Costs around $4,000, gives you a 60,000 LBS capacity.
    The mark IV GPS spoofer will have four antennas. Possession will be a felony. You'll be able to run it from your smart phone.
