If you have a cargo liner, is it more difficult to get access to the storage area below?
Discussion in 'Prius v Accessories and Modifications' started by eidling, Nov 29, 2013.
  1. eidling
    eidling Junior Member
    62
    In its stock condition, one lifts the rear carpet and there is a sort-of hinge one lifts to gain access. Is there much of a difference if one uses a cargo liner, such as Weathertech? I use that storage space regularly and am considering getting a cargo liner....
    thanks
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,976
    4,717
    Texas Hill Country
    Yes you have to move the liner which is a little clumsy
  3. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    The WeatherTech liner is light and flexible; I don't find lifting it a bother, but then I'm not frequently in and out of the storage area.
  4. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    If you're just accessing the rear most compartment, the liner can be folded back. If you want to access both compartments, the liner needs to be removed. Its not a big deal if the rear seats are down, you just slide it forward and out of the way. This assumes you are actually talking about the Prius wagon and not the hatchback, I don't know what its like in the hatchback.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    I own a Weathertech cargo liner.
    I like it. Fits perfectly, looks great.
    First of all, if needed you can remove the whole thing very easily. In other incidences where you might just want to access the storage below, it is very flexible so I don't find it to be a problem at all, I can just flip it up and open the space below.
    It's waterproof and very durable. Spendy, but I would recommend it, if a liner is important to you.
    If economic frugality is important, there are cheaper options, that might offer close to the same results.
    I made a cargo liner for my Honda Fit by just going to Home Depot and buying some indoor/outdoor carpet material. I think it cost me all of $8.
    PS.
    I justified the purchase of the Weathertech liner for The Prius on the basis of the battery being in the back. Having something that is waterproof and resistant to anything spilling in the back seemed to be more important.
    If The Prius was just a regular station wagon or hatch back....I probably would of just made another trip to Home Depot.
  6. Air_Boss
    3,952
    1,083
    New Yawk
    Likewise, it is the idea of protecting the battery location from sloshing fluids that made the WeatherTech economic decision easier.
  7. Kensterfly
    Kensterfly Junior Member
    95
    2013 Prius v wagon
    I have the WeatherTech, also. Price wasn't too bad considering I got $50 for the WT liner that came out of my brides Lexus RX, which we traded for the v5. The liner would be quite easy to remove, if need be. Don't let that be part of the decision process. You want more back there than just another floor mat.
  8. mikefocke
    3,701
    1,647
    Sanford, NC
    I keep a set of 3 practice golf clubs, a large umbrella, a better wheel lug nut removal tool than comes with the car, a shower curtain to kneel on, a half dozen golf balls, some miscellaneous tools, sprays, snow removal devices, etc in the compartments below the floor below the Weathertech. I keep the things I use frequently in the one nearest the rear and can one-hand the mat and lid to get at what I want quickly and easily. The stuff I use rarely go in the front most of the two compartments. The mat is so light, I can easily remove it. And if there is enough junk in the trunk, it would be a big deal to get at anything even without the mat. Love it. Had one in my CRV.
  9. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
    I just put mine in this week. Looks great, and it's fairly light and easy to remove or just lift out of the way. We bowl in leagues, and during the winter the bags and wheels get fairly wet. Nice not having to worry about slush and water ruining the cargo carpet. I've never used the second storage compartment because it was a bit of a pain to get to with just the carpet there.
  10. JasonW
    JasonW Junior Member
    30
    Texas : Austin Area
    Weathertech liner fits great, and lifts up easily enough to get into the compartment closest to the door. If you need to get in the farther back one, you have to work quite a bit harder, and it's a lot more awkward. Usually, I'll just remove the liner for a moment if I need into the 2nd compartment.
  11. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    I've had the huskyliner so long I forgot about the OE carpet. It is a little more cumbersome to move out of the way, but well worth the protection in my opinion as well.
  12. Alan Claver
    Alan Claver Junior Member
    79
    Central Pennsylvania
    The factory version is a 2 part mat so you can move the "lower" mat upward if you want to flip up the cargo area. Probably not as good if you want a continuous coverage as fluids can get between the two mats.
    My 2013 Prius came with the mats as a dealer add-on. I didn't have much choice as I wanted a Type V option model and my dealer in PA had to swap with someone in MD to get it. They are a very sturdy, heavy rubber version so I'm not sad I have them. I swapped them in around Nov and I'm pleased. The drivers mats are very sturdy, have the standard toggle clip to hold them down and they're a good compromise between slippery and sticky feel on the foot.
