Ignition coil info
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PriusMonkey, Jan 8, 2020.
  1. PriusMonkey
    PriusMonkey Junior Member
    Arizona
    Hello all,
    Probably going to to replace all my coils. I saw autozone has a 4 pack duralast for just under $300 that has a lifetime warranty. I know Denso is the OEM & usually best to go that route. Curious if anyone has had any experience with those. Also where you may recommend to get the desno's at a better price than the dealership. I'm trying to stay away from ebay with concern's of garbage fakes. Thanks!!
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    I’d buy it from a dealership on ebay
  3. pingd
    pingd Member
    97
    60
    Twin Cities, MN
    Am considering replacing same.
    Found this on Amazon and it seems a cheaper, reasonable alternative $133.25:
    search on Amazon for: New Set of 4 Delphi GN10341 Igntion Coils (link won't come through, sorry!)
    Also, I'm considering buying a used set (but only if there's good info about the donor vehicle).
